I regeared my LJ auto to 5.13 gears this past spring. It spent the summer in the garage and I am back to working on it. I've got about 400 miles on the new gears and took it out this week to test it at some higher speeds. I noticed a vibration that starts around 50mph and gets significantly worse with increased speed. I have narrowed down the vibrations to the rear driveshaft. I have removed the front shaft and had no change. With the rear shaft removed the vibrations are gone. I adjusted the rear pinon from 3 to 0 degrees below the driveshaft angle. The vibrations get worse the lower I set the pinion. At 0 degrees the vibrations were improved but still there. Above 65 they were bad enough I wouldn't want to drive very far. I pulled and inspected the yoke and output shaft but didn't find any obvious problems. I even set up a dial indicator to see if there was any runout on the output shaft. Everything checked out. I had replaced all of the u joints when I did the gears. Out of curiosity/desperation I adjusted the pinion to 1 degree above the driveshaft and had the best results yet. There are still vibrations that can be felt, heard, and seen in all of the mirrors but it is almost tolerable. I'm curious if anybody can enlighten me on why this might be happening?
