Painting door panels with SEM paint
I just did my interior with SEM. I used the sand fever adhesion promotor and it worked really well. I have a 97 with the light grey interior. Wanted to make it darker and add red accents. The sem laid down really well (I did use a spray booth which helped). The grey took 3 coats for perfect coverage. The red took 6-7 for full coverage. I haven’t gotten to the door panels yet, but I used 4 cans on the dash and center console. Make sure you get vinyl prep if you are doing the vinyl wrapped parts too.
The one pic shows the faded light grey against the new dark grey. Drying racks show all the little parts (there are a lot)!
this is the grey i've been looking for...can you tell me the code for the SEM paint color and where you got it from please?
It’s Graphite 15303. I got it from a local auto paint supplier, but you can also get it from Amazon.
Reactions: MountaineerTom
Thank you so much!!:cool: How do you feel about the paint holding up? Someone suggested to me that Vinyl needed to be dyed...not painted. Have you tried/heard any other applications for the dash/doors?
Not really any problems so far. It's only been several months, and I haven't driven it full time since it got back on the road, but it's holding up pretty well. The only problems so far are two: the passenger seat belt has scratched the paint on the side of the center console since it gets flipped up a lot when my daughter gets in and out, and the second is where I "fixed" the typical cracks in the front of the door panels...I used Bondo and it hasn't held up well. Will probably dig it out and just use caulk to seal it up.
Proper prep is the key. Make sure you use the correct prep stuff. I bought all SEM products to do it, was pricier but the results speak for themselves. The vinyl prep actually "melts" the top layer of vinyl to prepare it for paint.
Reactions: TJTurley
SEM products are the best. Redid my interio with the stuff and it it holding up with no issues. Vinyl pro will mix what you need and how you need it and will ship to your house.
Reactions: TJTurley
Well, door panels are painted but didn't quite hit the mark...I was really hoping the SEM 15303 was the right match but you can see from the pictures its lighter & is more blue then grey.
If anyone has the correct paint color match for 2000 TJ sport, please share!
Find the Chrysler color code for your Jeep and ask the SEM guys to give you the SEM match. If you don’t have a shop near by that can mix it, have the guys at 66Auto Color take care of you. https://www.66autocolor.com/
Here's all my old, faded stuff removed, washed and drying in the sun.
SEM Color Coat 15303 Graphite to replace the original light gray parts.
SEM Color Coat 15243 Satin Black to replace the original dark charcoal parts.
Reinstalling in Jeep. Note: I was not trying to match anything original or factory. I just wanted to revitalize my old faded parts with a new look (but keep it factory-looking if that makes any sense). Also, I did not use any kind of primer nor would I only because I don't think it's necessary for one and second, I don't like the idea of too much paint on top of the plastic. The adhesion promoter is responsible for the paint to adhere to the plastic.
Has the paint held up well?
Yes given the typical (normal) wear and tear has held up pretty well. One thing I like about this method is it is always easy to touch things up but so far haven't had to do that yet.
So after a bunch of research I came across these sites and maybe found a match to the 01 TJ interior Agate AZ code
Wish they just still made the door panels how hard could it be?
Color Code Charts
https://paintref.com/cgi-bin/paintdetail.cgi?painty=2002|Chrysler|AZ,AW7LAZ|376442
https://semproducts.com/public/content/techsheets/ACFN Color Coat and Sure Coat Formulas_0717.pdf
https://hdpaintcode.com/snippet-c-khdhbduc1D20.html
https://hdpaintcode.com/chrysler-main/
This last page had a Dodge cross reference to a paint code of LAZ / AZ - Agate Code 22135
Found it on this site here
https://www.genosgarage.com/product...iGZoclmrDysQ3ukn53wdzJrdFFYXCGssx2#minicart_a
Am ordering and will give it a try and see if it matches - wasn't cheap - 40$ for a can.
Still have to get all the SEM Clean and Prep Products too.
Oh and also fix "the crack" issue. :D
Just bought one on ebay and will see if I can repaint one to match that doesn't have a crack in it.
Just wanted to share since the forum has always been helpful for me.
Hope it is helpful and useful
Color Code Charts
This worked perfectly! The color was an exact match to Agate and I bought 2 more cans to have on hand :D!
The door I purchased was ok but very dirty and stained. Took a lot of cleaning and prep to get ready.
I expoxied Aluminum supports around the "Crack" areas on panel inside to provide extra support and prevent "Crack" on this door.
Use adhesion and 5 coats of paint but it looks like a brand new panel!
Am going to install and then repeat process on the existing panel and fix the crack and keep around the extra panel since so many TJ parts are getting Discontinued.
Hope this was helpful Good luck
To follow on this repaired the original panel that had cracked the same way and it looks brand new. This stuff looks and works great and if I were you I wouldn't do those drilling options to stop the crack. It's completely gone and invisible now and the seaweed epoxy coupled with the aluminum support will prevent retracting. Since this panel is no longer available I am definitely going to hold on to this one as a spare. Thanks again
I got some cans custom mixed from Vinyl Pro in the SEM 5545 instead of the SEM 15833 that I bought from Amazon. I thought they were the same, but the 15833 from Amazon was lighter colored. The 5545 is spot on in my opinion.
I just painted these half door panels with SEM 5545 from Vinyl Pro next to my OEM Khaki full doors.
This is a comparison of some small parts with SEM 5545 on the left and middle boxes and the 15833 from Amazon on the right box.
The doors look awasome . Did you use SEM Plastic & Leather Prep SEM-38353 and SEM 39863 Plastic Adhesion Promoter before you paited the doors ?
Thanks.
I used 77723 XXX Adhesion Promoter.
