did a search and found a threat with spring heights to lift height guide. So... best that i could measure... my front spring is about 15" WITH the spacer. The spacer seems to be a 1.75" spacer. So.. I'm at 13.25? Maybe just 13? Maybe 13.5? It's hard to tell. I can't measure to the springs lowest point. As the lowest point isn't on the outside by the tire. But on the inside. So where I can measure.. there is half a rotation of the coil going further down it seams (am I making sense?) The rear is also hard to measure. The rear is easier to measure from the top and bottom brackets (name?) that hold the spring. They have a lip on them so it's not a perfect measure of the spring. But that gap is 10". I can verify no body lift. But I can't really pin down my suspension lift overall. The chart when searching has 13 (before spacer) at 1" lift for the front. 14 for 2". So.. maybe its a 2" and im missing a whole inch when i measure? Because if it's 1" lift... then.. that's 2.75" total. And that seems like it can't be. It's running 33x12.5 tires. No rubbing. no wheel spacers. dont know the wheels backspacing though. I absolutely cannot tell what has been done lift wise. I can see it's lifted. I can see the spacer. I can see Rusty's lower control arms... and that's all I can tell. Anyone else able to decipher? Got any better guesses? I'm going to need shocks after the holidays sometime. And so it would be great to know what else has been done to better decide what else I may want to do myself before getting shocks. (For example... I don't care for spacers. But I probably need that extra height. Can I just get larger springs? Or is it just not that simple? PO didnt even do the lift. I think it was the PO before him. PO was under the impression it was a 4.5" lift. But I doubted that just from seeing it (though.. I don't call my self an expert. Obviously). i only feel more confused. not less. lol.
while I assume changes in vehicle weight effects the spring heights. I am guessing it takes a lot of weight to get a decent change in the spring height. these measurements where taken with nothing in the jeep. and the only thing added to the jeep with extra weight is the RC front bumper and and winch. and I dont know this for sure at all. but I would wager this would make an imperceivable difference in the spring height (like... MM's...maybe CM's... im just guessing far less then 1/8 inch difference... but im just guessing)
for clarification. this isnt a "what shock size do i need" post. if I where to leave the lift alone, I can detirmin the shock length needed (measure shocks on jeep. find shock close to that when half extended, etc). what I am trying to do is determine what I may want to do to the lift, before deciding on shock replacements. while this isnt the way I would have done the lift myself.... because its already on there... I am seeing if I can just make use of whats there with minor changes... or if I want to start over and save for an entire lift kit... thats the more expensive option. so I want to see about 3 things basically...
1. keep the same everything. just get socks and call it a day.
2. keep same lift height... but change any parts needed so that the spacer isnt there (again... is it as simple as just getting springs that have the appropriate height to equal what I know have between the spring and the spacer combined?)
3. replace parts needed to go ahead and get a bigger lift (and then... what parts... everything needed in a lift kit or.... do I potentially already have the needed parts from the current lift so that a larger lift doesnt need everything in a kit.. and thus making a lift kit leaving me with redundant parts)
the last time I installed a lift myself was getting close to 20 years ago. everything since then as already had a lift on it... or.... I took it to a shop and had them to it (back when this was a more affordable option for me). and since I dont remember jack about the 1 time i did install one... 20 years ago... its safe to assume I have a sever lack of knowledge here and whats going on.. certainly when it comes to figure out whats been done already to this jeep. its one thing to replace parts sent to you in a kit. its another to have knowledge on whats going on and spot stock vs aftermarket and knowing offhand what parts are needed when lifting at various heights... etc.
I have looked at many many threads on this.... which really just left me with more questions (for example... how is it I seem to be measuring less then 3" lift... when the many threads I have found seem to all agree 4" or more are needed for these 33x12.5 tires. yet with no spacers.. no aftermarket or cut fenders... my jeep has no rubbing or any VISABLE issues running this tire size? other then feeling like new shocks may be in order soon... it drives pretty well honestly. so i dont suspect any funny business really.
