Rear End Confusion
2005 wrangler X ?
There And Back Again
Maine
So My build sheet says I have Dana 30 on the front, Dana M35 on the rear
WITH Command Track
My question is this
1-Do I have limited slip in the rear ?
2-what gear oil should I be using?
3-what gasket INTEAD of RTV --link please
its got 42,000 on it and i dont think its ever been changed out :(
Geez...only 42K miles? Dana 30 front diff and Dana 35 rear use 80/90 or 75/85 type GL5 gear oil. The 4wd configuration is "command trac" which takes ATF of your favorite flavor. dex/merc III is fine as well as M1 synthetic type lubes.
Reactions: 2005 wrangler X ?
Does your build sheet say "Trac-Lok"? That is limited slip. Command-Trac is what Jeep calls your 4 wheel drive (having a Transfer case with 4hi and 4lo)
sections Copied and pasted of my PDF build sheet
I see nothing saying Trac-Lock
ALL 4-SPEED AUTOMATIC TRANSMISSIONS
COMMAND-TRAC PART TIME 4WD SYSTEM
DANA 30/186MM FRONT AXLE
DANA M35/194MM REAR AXLE
U.S. DEALER RETAIL
ZONE 32-NEW YORK
TJ-VEHICLE FAMILY
FOUR WHEEL DRIVE (4WD)/(4X4)
VEHICLE ORDER TRACKING
U.S. SPECIFICATIONS LABEL
CONNECTICUT SHIP TO STATE CODE
CONNECTICUT SOLD TO STATE CODE
4-SPD. AUTOMATIC 42RLE TRANSMISSION
LOCK-UP TORQUE CONVERTER
3.73 REAR AXLE RATIO
4.0L I6 POWER TECH ENGINE
LIGHT TINT FRONT DOOR WINDOWS
FULL METAL DOORS W/ROLL-UP WINDOWS
AIR CONDITIONING
COURTESY LAMPS
UNDERHOOD LAMP
50 STATE EMISSIONS
FEDERAL TIER 2, BIN 9A EMISSIONS
NEXT GENERATION ENGINE CONTROLLER
No rear locker. However if you're not the original owner who knows what was modified.
Is it a Sahara?
Reactions: ChadH
The front end is the way you’re looking. The rear end is the way you’re not looking. Also, there’s a pointy thing on the front end. The rear shouldn’t have anything pointy near it.
1-no
2-GL5
3-LubeLocker
thanks for the link :)
Is it a Sahara?
sorry for my stupidity, what do you mean by No rear locker?
No its an X model the covers have not been removed that i can tell
build sheet---Vehicle Description 2005 JEEP WRANGLER X 4X4 SPORT UTILITY 2-DR
and more of the build sheet posted above
No positraction or device that would lock the two wheels together so they both provide traction.
At least according to the build sheet. Who knows what was modified by previous owners.
"IF" theres no modification and its Stock/Factory, does that mean in 4wd im actually only using "1" of the rear tires? until it slips
imOLD and in my teens you had limited slip 1-wheel rear drive
OR
posi rear end for hell of a burnout :) and launching off the line
hence all my confusion. as i know zip of 4wd
Correct. 4 x 4 sans lockers is one wheel in the front and one in the rear.
Command Trac is strange. That's usually in Saharas and XJs and ZJs. I think. What's your 4 wheel drive lever look like? 2wd, 4 hi, neutral and 4 low?
yes on your description of my lever
OR
In normal 4x4 mode you'll have power to both wheels that have traction. When one wheel loses traction, neither wheel on that axle will have power. This is why lockers are so great. Both wheels get power no matter whether they have traction or not.
Edited as per below.
In normal 4x4 mode you'll have power to both wheels that have traction. When one wheel loses traction, all the power goes to the wheel without traction. The other wheel that has traction will not be getting any power. This is why lockers are so great. Both wheels get power no matter whether they have traction or not.
so in 4wd im getting power to all 4 tires ? until one spins out front or rear then the squirrels run to the opposite side and jumps on the squirrel cage and starts running all out? until everything stops spinning
or are you saying ive got power to both wheels---1in front 1-in back until one front or rear starts spinning then it changes over to the opposite wheel on same axle
WTF to me thats NOT 4wheel drive,,,that 2wheelgoofydrive
Differentials distribute torque equally.
When a tire spins with no traction, such as it’s hanging in the air, it has no torque so the other wheel on that open differential axle with traction stops spinning because torque equalization now means its torque is zero too.
Reactions: Mike_H
This is how a differential works
You have two differentials, one in front, one in back. In two wheel drive, the rear axle is providing all the motive power. If one wheel loses traction, it will spin and you will lose motive power (since there is no resistance on the traction free tire).
In four wheel drive with open differentials (the type you have), you double the motive power applied to the ground. 1x rear axle + 1x front axle. Again, if a tire loses traction, it will spin and you’ll get no power. But, since you have two axles providing power, a tire on BOTH axles have to lose traction to stop Motive power.
So 4x4 is a misnomer, but still better than 4x2.
You should just build a tube buggy, that way you'll know what you have.
