I've been dealing with an intermittent problem. A few months ago I would get a rubbing or catching sound from the drivers front wheel when turning from a stop. This would only happen when I first started out, and then go away as I drove. I brought my car into the garage, jacked up the front, and rotated the tire by hand. I could feel resistance and hear a clunk as I rotated the tire. It would make the noise about every 1/4 to 1/3 rotation of the tire. I took the brake caliper off and rotor, in hopes of finding an issue. I put it all back together and it was fine for a couple months. zero issues.
Fast forward to a couple days ago, and it started again on the same tire. Only this time, it was doing it with the wheels straight and seemed to not go away. I brought it back in and was getting a dragging noise/feel every 1/2 to full rotation of the wheel. I again took the wheel, caliper and rotor off. No visible signs of concern. Sure enough, the issue was gone once I put it back together.
I'm not seeing any issue with the brake caliper or rotor. I'm unsure why the issue comes and goes. Could it be hub? u joints? or brakes? The u joints are firm, although I've heard they can dry out and still feel solid with no play. The pads about 80-90% new. If the caliper was sticking, shouldn't it be all the time, not just in a spots while rotating the wheel? I'm just unsure what could be causing the intermittent issue?
