It's a conundrum but I'll try to keep it relatively simple
Jeep is currently in CA
Jeep is registered in FL and was ordered / delivered to South Georgia dealer when I lived in FL full time.
In the time that the jeep has been here, the cats went south and my fuel economy has tanked massively. Yes I've checked sensors and vacuum lines, etc and it's narrowed down to the fact that the substrate or whatever it's called in the mini cats has blown out or disintegrated and the o2 sensors are reporting the absence of that honeycomb filter to the computer and it's sending WAY too much fuel like 30% too much. I'm not registering it in CA as it won't be staying here for long, but under the hood it says it was shipped with California compliant exhaust on that "CATALYST" decal.
Question is two fold:
1) If I install EPA cats (both the Y pipe with mini cats and rear cat) this time versus putting on CARB compliant parts, will that upset the computer / o2 sensor / fuel trim such that will cause the engine to run too rich or lean or anything of the sort or will any difference be even noticeable?
2) If I go the EPA compliant parts route (which will be half the cost) I can't get EPA cats sent to CA because no one will ship them to CA. I don't want to drive it cross country with the horrible mileage it's getting due to the o2 sensors causing it to run too rich and use WAY too much fuel so I want to swap them before that drive takes place. If putting EPA parts on won't cause a problem with any configuration or such as mentioned in question #1, how can I best get a hold of these parts?? Is there a 3rd party that could / would receive a package on my behalf (even if i had to drive to Vegas or such to pick it up) that I could take back, install, and prep to drive cross country??
I really don't want to spring for CARB parts if it's not going to stay in CA.
Thanks for your time!!
