Wow, great build thread with impressive mods, craftsmanship and detailed directions. Thank you @OldBuzzard!
Fog Light Power Relay
Chrysler ran the full power for the headlights through the Multi-Function Switch (MFS) on the steering column. Ditto on the fog lights. That's a poor engineering design, but it was probably a cost-control decision, saving a few bucks on relays. Most TJ owners know how abysmal the stock headlights are, partially due to the skinny wiring. And some have had to replace a burned up MFS.
My very first mod several years ago, after driving it 300 miles home from purchase, over several mountain passes, in the dark, was to add heavier wiring and relays for the headlights. And better H4 halogen lamps.
Now it's time to upgrade the circuit for the fog lights. The Factory Service Manual (FSM) for 2005 has the fog light wiring diagrams on pages 8W-50-3 and 8W-50-10.
View attachment 585206 View attachment 585207
There is an OEM fog light relay, but it just disables the fog lights when the high beams are on. That's not a problem, since in heavy fog or a blizzard you don't want the high beams on, or the low beams, you just want the fogs (if they're real fogs). I'll add a power relay under the hood to keep the high current out of the MFS. I would like to increase the wire size to the fogs (18 gauge is just barely adequate, 16 or 14 would be better), but I'll keep the OEM wires (for now).
I decided it would be easier to open the PDC (Power Distribution Center) than to dig into the big wire bundle on the firewall. This may or may not be the best place to access the fog wire. The OEM fog relay has a WT/OR (white-with-orange-stripe) 18-gauge wire coming out of it. That's the wire which feeds power to the fog lights. I cut that wire.
I cut two pieces of yellow 16-gauge primary wire and threaded them through the big wire bundle and into the PDC. I marked them with colored shrink tube (on both ends) for identification, and crimped them to the ends of the OEM wires, and sealed them with shrink tube.
Where they exit the big wire bundle, just below the PDC, I slid on some split conduit (aka Flexible Tubing aka Protective Wire Wrap) and taped it all up.
I crimped female disconnects on these wires, and ran them to a new Bosch relay. I have a trailer electrical box hanging from the passenger-side grille support rod, along with a ground bus. I mounted the relay to an aluminum plate, and hung it on the same rod using a 5/16" wire rope clip from Ace Hardware. I made power and ground wires, with an ATC fuse holder, and wired those in place.
This is my wiring diagram for the new power relay:
Everything works just like it always did, but the 9 amps (measured) feeding the fog lights no longer flows through the MFS.
Fog Light Yellow Lenses
The OEM fog lights have a good pattern (wide, with sharp top cutoff), but real fog lights should be yellow or amber, which reduces reflection from the fog or falling snow.
I bought a 6" x 12" sheet of yellow Lamin-X film. It comes as a kit with good instructions, a knife, a squeegee, and a spray bottle.
I removed the bezels and lamps from the housings (3 T-20 Torx), leaving the housings on the bumper. The bezel just stretches to pop off the lamp. My lamps are lightly pitted and have some slight cracks from 20 years on the road. The surfaces are flat, so they're easy to laminate onto.
The OEM fog lights have a 6" face, with 1/8" covered all around by the plastic bezel. The Lamin-X is a smidge short of 6x12. I cut it exactly in half, and followed the instructions carefully (easy). Holding it by the corners, I had to reposition the film a few times to get it centered. Since the film is a bit short, it leaves a small gap at the edges, which will be covered by the bezel.
After using the squeegee to remove the bubbles, I reassembled everything.
I followed the FSM alignment specs, straight ahead and 4" down at 25 feet. Straight ahead is easy, since the housings are pinned to the bumpers in that position. It only took one tweak on one side (another T20 Torx at the rear of the base) to lower one lamp slightly. You can see the very wide pattern with sharp cutoffs top and bottom.
Now I just need to find a blizzard to play in.
They fit that rod so perfectly that you can't just push them on over the rod, you have to put them on at the front end where the rod is flat and then slide them along the rod.These little wire clamps are a cool cheap way to attach stuff to those strut rods, nice. I see you've used them more than this one time lol
I was surprised at how thin that pattern was. I expected a sharp cutoff on top, but no cutoff on the bottom. Now I want to see what they do in a blizzard.My KC fogs had a pattern NOTHING like that. That is wild.
Recovery Gear
I've had some pretty mediocre recovery gear in the Jeep for a few years: cheap tow ropes, receiver shackle, no winch. I recently replaced the rear bumper with a Dirtworx with built-in recovery points and D-rings.
Thanks to @mrblaine's very generous prizes for the ROTM contest, I'm able to do some more upgrades.
WRG front Recovery Points - Soft Shackle Friendly
I removed the OEM horns and installed Blaine's recovery points.
The pusher pads were in the way, so I drilled two holes and moved them inboard a little (had to remove the bumper). I haven't actually used the pusher pads on this Jeep, but I used them several times on my old CJ5 (made from exploded semi truck tires). So I wanted to keep them.
WRG Soft Shackles
Four of Blaine's soft shackles.
TRE kinetic recovery rope
Tactical Recovery Equipment (TRE) Kinetic Recovery Rope, 3/4", 30 ft, 18,000 lb. breaking strength, for vehicles up to 6,000 lbs.
Fenix sent me an email today on their smallest headlamp, the HM50R V2.0 and I just now ordered one 10% off.
Those recovery points look like they came that way from the factory on the OEM bumper. Very good design and sad more people did not see just how nice these were (they are discontinued now at WRG). I am very glad to have a set on my Orange jeep that Blaine is building for me.
Discontinued? I still see them there:
https://blackmagicbrakes.com/ols/categories/wizard-recovery-gear (middle column, second row)
https://blackmagicbrakes.com/ols/products/recovery-points-soft-shackle-friendly
Once they are gone, they are gone.
https://wranglertjforum.com/threads/soft-shackle-friendly-recovery-points.83126/
