And what are those codes?
P0016 is basically that the camshaft and crankshaft are not in sync
P2308 is ignition coil issues, which I think is due to the starting issues caused by the crankshaft
What happens when you plug everything back in?
It’s hard to start and then it runs real poorly, and if I don’t give it gas it dies.
Okay, I will go through them all again. It is strange because it ran perfectly before and the TT is not very intrusive in the engine compartment. If you have any other ideas, I’d appreciate it.I still suspect that you have a different issue from the previous owner not plugging a sensor in properly that was disrupted from
I’ll check the wiring, but if I try it with the crank sensor connected and the cam sensor disconnected and it does the same thing, what would that mean?You need to check the crank sensor wiring. If I'm reading this correctly you tried a new crank sensor and had the same problem, but it runs OK with no crank sensor.
You can also try running it with the crank sensor connected, but the cam sensor disconnected.
Have you looked to see if your OPDA is loose ?
It’s a long shot. Might me unrelated to the TT.
The crank sensor circuit has a problem if it only has the issue when the crank sensor is connected.
Ok, i misread that, you were running with the crank sensor only when it ran OK?
I used a wrench to get to TDC, adjusted the OPDA and boom.
