Split D-Ring Shackles, Opinions?
Don Bulee
Mex
I was looking for a cheap kinetic rope in amazon (I was recently pulled by a friend a few blocks to my house because of a bad starter) and I saw these split d ring shackles, in which you won't need to remove them from your anchor point to be able to put your rope in it, they are a little more expensive but, what are your thoughts about these ones? there are several brands, which is not my question, more like the design of the shackles... thanks!
https://www.amazon.com/AUTOBOTS-Tig...Accessories/dp/B0D1KC2CH3/?tag=wranglerorg-20
If you think about it it's not really a shackle but two J recovery hooks facing opposite directions. Since they have open ends and are not one solid piece I doubt they are as strong as a standard shackle no matter what they claim. I also don't like the non-radiused sharp edges for obvious reasons. I think this "shackle" is a gimmick.
Soft shackles are all you need
I have several and usually use them, but when I need to be pulled from the front bumper the D-ring is what is on the bumper, or you mean that I should attach the soft shackle into the normal D-ring?
If you think about it it's not really a shackle but two J recovery hooks facing opposite directions. Since have open ends and not one solid piece I doubt they are as strong as a standard shackle no matter what they claim. I also don't like the non-radiused sharp edges for obvious reasons. I think this "shackle" is a gimmick.
my thoughts as well.... if I need to be pulled from a different angle I wouldn't trust them as a normal dring shackle..
The soft shackle goes directly to the bumper. That is what they are for, among a dozen other things.
Reactions: Don Bulee
All the more reason to use a soft shackle. A side pull does not add leverage to the bumper the way a steel shackle does when it binds from a side pull.
These stacked J hook thingies are just more cute bumper jewelry to decorate your Jeep with.
The ones from Moose are smoother.
https://www.amazon.com/Moose-Knuckle-Offroad-Split-Shackle/dp/B0BQ1SHD4G/?tag=wranglerorg-20
Yes. Soft shackle to link D ring to your pull rope. Safest way. 🇺🇸
looks like a knockoff of mooseknuckle, but it is an answer to a question nobody asked. When you are recovering another vehicle, slowing down is a good thing.
I agree with @jjvw, I think is only for the looks and more for a mall crawler, I think I would just keep using my soft shackles instead.. but, ey! worth the trend just to discuss it I think...
With those, you can't use them for any other rigging like a snatch block or line extension.
I have one standard shackle on my bumper with my winch cable, one on a receiver shackle mount and two soft shackles in my recovery bag.
Also, a kinetic strap/rope and a tow strap/rope are two different pieces of gear with different uses. I have one of each and two tree savers in there as well.
One strong argument against these stacked J hook things in favor of soft shackles is that with soft shackles nothing needs to be kept hanging on the bumper.
I hook my winch line to it since I run a standard hook that doesn't fit behind my license plate bracket very well.
