Just had the 32rh (904) 3 speed automatic in the 2002 rebuilt. Shop said they put new torque converter in it. Everything seems fine so far but I've noticed when im going down the highway at 55mph I'm running 2500rpms. Is this normal?
Man I wouldn't know for sure. I'll say this. It didn't run at 2500 with the factory tranny in it. But I had a ton of other issues with the factory tranny. Not sure if the other tranny should have been running higher or if this one is too high.
Well, it’s difficult to give you any help over the internet with the limited information available. You need to know 3 of the 4 variables in order to calculate the unknown (tire diameter, RPM, MPH, gear ratio).
It’s easy enough to compare the dash speedo reading vs. a GPS speed reading, and you can lift a wheel and count revolutions of tire vs driveshaft to get a gear ratio estimate.
The only thing I can think of is to ensure you feel the transmission shifting to third gear to make sure it’s not in second, which would make the RPM a lot higher than typical.
Need to know the gear ratio,I run 63-65 mph at 3000,4.56 gear
What's your gearing and tire size
I know the tires are 33's. There is a rough country lift so the speedometer is off. I have a 2002 X model so according to my research its most likely a 373 gear but could be a 3.07. I will download a speedometer app to verify the speed and get back with you. I can feel the transmission shift into 3rd gear. What i'm not feeling is once its wound up to highway speed (at least 50 mph up to 65 mph it holds at a steady 2500 rpms. Does this help?
Buy the correct tooth speedo gear once you see what the rear diff tag says.I know the tires are 33's. There is a rough country lift so the speedometer is off. I have a 2002 X model so according to my research its most likely a 373 gear but could be a 3.07.
... 33’s actually are around 31.5” large and my calculations reflect that.
