Are these RPMs normal for a 32RH?
Jellis
Ashland Ky
Just had the 32rh (904) 3 speed automatic in the 2002 rebuilt. Shop said they put new torque converter in it. Everything seems fine so far but I've noticed when im going down the highway at 55mph I'm running 2500rpms. Is this normal?
Gear ratio calculator says around 4.33:1 gear ratio with those tires and RPM @ 55 MPH. Are you sure the speedometer is accurate?
Man I wouldn't know for sure. I'll say this. It didn't run at 2500 with the factory tranny in it. But I had a ton of other issues with the factory tranny. Not sure if the other tranny should have been running higher or if this one is too high.
Well, it’s difficult to give you any help over the internet with the limited information available. You need to know 3 of the 4 variables in order to calculate the unknown (tire diameter, RPM, MPH, gear ratio).
It’s easy enough to compare the dash speedo reading vs. a GPS speed reading, and you can lift a wheel and count revolutions of tire vs driveshaft to get a gear ratio estimate.
The only thing I can think of is to ensure you feel the transmission shifting to third gear to make sure it’s not in second, which would make the RPM a lot higher than typical.
Need to know the gear ratio,I run 63-65 mph at 3000,4.56 gear
And then feel the torque converter lock up afterwards
Reactions: ColoJeep
I know the tires are 33's. There is a rough country lift so the speedometer is off. I have a 2002 X model so according to my research its most likely a 373 gear but could be a 3.07. I will download a speedometer app to verify the speed and get back with you. I can feel the transmission shift into 3rd gear. What i'm not feeling is once its wound up to highway speed (at least 50 mph up to 65 mph it holds at a steady 2500 rpms. Does this help?
What's your gearing and tire size
The lift height is irrelevant. To figure out the axle gearing, you need the tire size, transmission and an accurate speed that gets you into the transmission's final drive gear.
@hear is the 32rh guru.
So from 50mph to 65mph, your RPMs hold steady 2500? I would guess your torque converter is not locking. Check the torque converter clutch plug. With the recent work, I wonder if someone did not plug it back in. Or, with your speedometer being off it is causing the PCM and TCC to be off.
33’s and 4.11 gears would end up right at 2400 rpm at 55 mph. It’s probably a slight discrepancy in the speedometer and you likely have 33’s and 4.11 gears. We can’t help any more than that with the limited info. 33’s actually are around 31.5” large and my calculations reflect that.
It can’t hold the same rpm from 50-65 mph, that makes no sense.
Reactions: hear and jjvw
Buy the correct tooth speedo gear once you see what the rear diff tag says.
Reactions: macleanflood
And measure your tires. Not all 33" tires are exactly 33. I have 35" BFGs and they're 34.5". My wife's Mickey Thompson 35s are 33".
As said above, the lift has no impact on the speedometer being off - that is caused by tires that are a different size than factory, or a gear ratio that is different than factory.
If it shifts fine from 1-3 and then has about 200rpm drop when the converter locks it doesn't matter what tires,gears or rpms it has.
Reactions: hear
