Did you repaint or deep clean the das. If repaint... How did you match the "khaki" color?
Just deep cleaned! I have a cheap HF steam cleaner that I used. I sprayed areas with Simple Green and let it saturate for a few minutes, then hit the sprayed areas with the steam cleaner to break solids away, then wiped clean. It’s time consuming but effective.
