The big reason to do this is to fit a shock that can be tuned. The shock is also going to be longer because that contributes to the tune, and more suspension travel is beneficial in the rocks, and the lower mount can be raised.
The wider shock stance is a bit of a byproduct of the process that also improves the tuned shock's ability to control movement.
Okay I had the purpose vs side effects backwards.
You are entering into the realm of building specifically for shocks and making the shocks work. The form of the mounts are determined by the function of the shocks.
If you end up liking the results, then you run the risk of wanting more of it because of how transformative the shocks are to the fundamental core of how the Jeep behaves and performs. Everything changes if you go down this road.
Yeah between riding in Matt's, Ben's new Blaine build, and Jeff's this year, I'm realizing mine rides like absolute dog water. I know Jeff's is different with the COs but they all have shocks that are significantly less crappy than mine
I was pretty happy to learn that the tuning is more in the realm of affordability than I thought, and doesn't need to be done all at the same time. Much more motivated to do it after that
