What is the best way to test the ECM to see if it is working correctly.
Start the Jeep.
What is happening that makes you think the PCM is not working correctly?
Working on my sons 1999, manual trans 4.0 L, TJ that won't stay running & battery not keeping full charge. My son has replaced many parts already... new fuel pump, crank sensor, new battery, alternator & starter, ignition switch etc. I'm thinking PCM. I've replaced the PCM on my 2006 TJ 4.0L automatic trans with a new WranglerFix, high performance tune, because I had the hard 1st-second shift which it fixed. Now my question... can I try and plug my old PCM, 2006 auto, into the 1999 manual TJ to see if that would fix the running problem without damaging anything before he buys a new one from WrangleFix? Does the PCM have to be close to the year & trans of the TJ just to test a engine running issue? No codes are shone.
Will be visiting my son this 4th of July weekend and will be working on his TJ.
How about switching the computer with one from a 2001 manual transmission? Just want to rule out the PCM is not the cause of the Jeep not starting. Since there is no check engine warning light being shone I think that maybe that is the reason for the new fuel pump not running. My son is very worried about me changing the computer thinking it will cause damage to it or the Jeep and leave him with 2 non running Jeeps. I don't want to be "holding the bag" if it does. He refuses to "throw in the towel", admit defeat and have it towed to a professional mechanic even if I offered to pay...
Here's a ideer, send it to Mark and have him test it ! THAT WAS EASY .....
Gave my son the phone # & address of WranglerFix to do that about a month ago... he, for some reason, won't do it.
