Getting ready to install my savvy cable shifter and was curious would it be better to do the install in 2HI or 4LO? Thanks
Not so much 4 high, but 2 high and 4 low and it’ll take a few tries to get it adjusted just right to hit the full range.
I guess my other question would be if I need to make adjustments would I need to pull skid plate off everytime I adjust it? Thanks all
Probably would be easier but I did the entire install and adjustment without removing the skid. So, up to you
"So for installation,no explanation is needed; for adjustment, no explanation is possible!"
I did mine in 2HI, which IIRC, is when the bottom of the actuator is pushed all the way to the rear of the Jeep. When I installed mine, I didn't have to adjust it at all. It went through all 3 gears and N seamlessly. One of my favorite mods, finally got to use 4LO.
I didn't take my skid off. HUGE regret. Drop the skid.
You should be able to get it adjusted correctly on the first try, before reinstalling the skid.
But adjustment boils down to loosening one stop-nut on the cable, and then turning the stop-nuts by hand, and then tightening it back up. That's do-able with the skid in place, if you're a little flexible.
Not sure where that is from but it is anything but true. Housing controls the throw, cable controls the length. Length sets the at rest position in the detents, cable housing sets how far the levers move."So for installation,no explanation is needed; for adjustment, no explanation is possible!"
No truer words spoken.
It came from the link to instructions Zorba posted above. I thought it was funny. I started wrenching on my own bikes when I was a little kid and cables and housing cause me no stress. But would I want to explain to my neighbor how to set up an 11 spd derailleur? No I would not.
I spaced the skid off the frame with some large 7/8" galvanized washers - I think that's the best thing to do to prevent (further) rust in that area.
