Daily Driver, Go Where I Want To Build
Got a complete 2003 black agate dash from @hosejockey61 's recent part out Jeep.
This will match the black carpet I already have sitting in a box from @psrivats 's current project.
No more grey interior!
I'm slowly gathering parts to make a bed mounted tire carrier.
This is going to be a flat table at wheel well height that is hinged at the seats. The tire will be secured with the Y-strap.
I ordered stainless D-rings each with a 400lb working load. Functionally I know this works. But aesthetically, they feel small. 🤣
I hook my Mac tire strap to the bars under each of my seats and to the rear seat mount bracket.
I look forward to seeing this “hinged” table you speak of.
Reactions: Tob
This is a Blaine inspired version of something he did a while back. I think by the time it is done, it won't look like much. But a lot will have gone into it being enough without being too much.
This is a Blaine inspired version of something he did a while back. I think by the time it is done, it won't look like much. But a lot will have gone into it being just enough.
Are you giving it the whole nine yards and adding the actuators? :geek:
I’ve been trying to figure out a solution, and I’m not aware of the Blaine solution, but anxious to see.
Mostly this, I think...
A roughly 36x40ish sheet of 1/8" aluminum goes on top for the tire to rest on.
With help and guidance from Blaine I was able to piece together a set of Savvy trail doors that keep the original subtle design intents.
The function on these is a lot of fun and so much nicer to use than my BesTop lowers.
There are two intuitive ways to activate the latch. The remote paddle latch release is easily accessible in front of your knee to get out. No more reaching behind to fight with the J handle. To get in, grab the door where you instinctively would and reach a finger down to the length of cable in front of the latch and pull up to release the latch. I built the cable to be just barely tight so that there is very little cable travel and movement required to move the latch. The latch itself is very direct and snappy.
Once aligned and the little shim is installed on the body side door catch, the doors open and close with little effort and do not rattle. And the wide arm rest is very comfortable.
