With help and guidance from Blaine I was able to piece together a set of Savvy trail doors that keep the original subtle design intents.
The function on these is a lot of fun and so much nicer to use than my BesTop lowers.
There are two intuitive ways to activate the latch. The remote paddle latch release is easily accessible in front of your knee to get out. No more reaching behind to fight with the J handle. To get in, grab the door where you instinctively would and reach a finger down to the length of cable in front of the latch and pull up to release the latch. I built the cable to be just barely tight so that there is very little cable travel and movement required to move the latch. The latch itself is very direct and snappy.
Once aligned and the little shim is installed on the body side door catch, the doors open and close with little effort and do not rattle. And the wide arm rest is very comfortable.
Didn’t realize you were working on this. I was very close to having one of our vendors duplicate my doors until the OG Savvy ones popped up.
I also swapped out the hex stuff for button heads, much cleaner look. I plasti dipped the paddles on my old set.
Here’s one other addition that I like on these new ones and a reason I got all new hardware for my old set. Easy enough to make if you desire.
