Where else did I bring it up?
I learned of Rory’s opinion from a post you made. Then I saw you mention it again (both before today).
They are in your history.
Here's the only other time I recall discussing it.
https://wranglertjforum.com/threads/nashville-tjs-build-continued.42035/post-1668627
I’m interested in the “why” behind the posts, not the “where” and “when”.
There’s a reason for why we do things, and that’s what I am attempting to learn.
You’re going to have to spoon feed me what you’re getting at.
Everything I've said here and in Jeff’s thread seem pretty self explanatory.
Why bring up Rory's negative opinions of 5.38s?
If that's true, then you should find it easy to answer my question. I also request to be spoon fed.
I don’t believe I’m the one with the comprehension problem. You have a point you want to make. Make it.
While I can't say I totally agree with Rory I do know that I've broken 3 5.13 gear sets.
1) 35" tires but I think it was due to a loose pinion nut.
2) 38" tires but installed by a professional shop who I trusted
3) 38" tires installed by a 2nd shop
4) Super 60 R&P I installed so we'll see what happens. Also installed a load bolt with tight BL.
Using KOH rigs as an example compared to our rigs isn't even close to apples to apples.
Jeff is heavy just like mine is. Does that matter? I'm sure it does.
Remember he was running a HP60 in the rear of his rig same as mine. We're all shocked that he broke a 14 bolt...
My understanding on the 5.89 gears there is actually more teeth contact. I could be mistaken but that is what I know.
I comprehend your little dig just fine.
You just asked me to spoon feed you, which I did by asking the direct question "Why bring up Rory's negative opinions of 5.38s?".
You then refused to answer, and we know you refused to answer since you don't have a comprehension problem.
That tells me all I need to know.
That breakage for you was a hi pinion in the rear both times?
I’ve already said why I brought it up.
Again, you have something you want to say. Say it.
If you said why you brought it up, then please share the post.
The breakage has been in my CRD60 all 3 times. once on 35" tires & twice on 38" tires. I'll be swapping to a 14 Bolt or 10.5" Ford if I break again.
Did you have a load bolt before?
No. That was the addition along with the Super60.
I think that will significantly help
Scroll back a couple or so pages and start reading
I read it. You never explained why you keep bringing up Rory's opinion of 5.38s in multiple threads.
If you don't agree with Rory's opinion, then why do you repeatedly post his opinion?
If you do agree with Rory's opinion, then why do you plan to install 5.38s in your big boy rig?
I shall end my participation with a message in your native language...
