Are you trying anything new or different to eliminate the creaking/squeaking in your JJ’s on your control arms?
I recently removed and relubed my rear lowers that were creaking bad. When I get around to doing the rear uppers, I’m going to try something. I got a set of the upper bushings for my Savvy JJ’s from @JMT 2 or 3 years ago. I used my Dremel tool to cut some small grooves in the inner surface (like another member here did, but I can’t remember their name) where the ball rides. I’m going to see if it will make it possible to get some grease in there throught the zerks. If it works, I’ll end up doing the rest.
Haven't tried anything new with the JJs. Rear is creaking a lot more than front right now, I need to dig up that thread where I posted which grease I used in which arms. I know some right now have cv2 and others have superlube silicone w/ptfe. For the uppers I'm gonna go back with whatever I used in the front since it seems to have lasted longer.
I have a pair of the metalcloak duroflex bushings that go into the larger JJ housing, so I think I'm gonna try those in my rear LCA (which only have a JJ in the forged/frame end, while the axle end has already been replaced with synergy ddb).
Will be interesting to hear how you do with cutting the grooves. I've thought about it some but I'm terrible at freehanding that sort of thing.
