My '99 SE is doing something odd. When I bought it a year ago, the heater core was leaking, so I didn't run the ventilation (don't know if this was a pre-existing problem). I recently replaced the heater core and AC evaporator (AC isn't running yet). The air blend door looked OK. The ventilation blows hot when the Jeep is hot, when the knob is set on cold (it blows cool air until the Jeep is hot). I replaced the blend door actuator, wondering if the old one was getting flaky when hot, but no change. The blend door swings freely by hand.
Does anyone know of anything else I can check? Is it possible that the blend door edge is 'curling' as it gets hot, or getting flimsy and leaking air past the heater core? I know there's an outfit (Heater Treater) that sells replacement doors, and you cut through the bottom of the ventilation plenum(?) and cut out the old one, I'd just rather not do that if there's something else I can check first. The fan works fine and the position selector (defrost, vents, floor) works fine.
Thanks
Thanks
