Unreal. Defrost 98 degrees on high. One speed back 105, one more back 125, on low 148. Should I have constant drip from ac evaporater lime comin.out from firewall on defrost
Like I said earlier you have a flow issue. You don't have the correct volume of coolant going through the heater core.
With the fan on high the low volume of coolant is cooled much quicker, causing lack of heat.
Go drive it around for 20-30 minutes, get it up to temp , so we know the thermostat has cycled a couple times
Taking readings with the IR thermometer at the upper heater hose, if you check the temp in several places starting at the nipple off the thermostat housing and working you way back to the heater core, do you have a temp of at least 155-160 degrees?
Now do the same on the lower hose, but start at the heater core and work your way back to the coolant pipe off the water pump.
What are your temp readings?
What we are trying to do is determine if there is a lack of flow going to the core, a partial clog in the core, or a blockage going back to the water pump.
You don't know what the service history of your jeep was prior to buying it, That is why I suggested removing your thermostat and performing a coolant flush and back flushing prior to replacing the radiator.
It does not take a lot of rust or scale to partially clog a heater core.
