Flat tire has me here checking brakes, have not seen shoes with a groove before 🤷🏽‍♂️. Seems odd to limit surface friction to this level, but note the drum. A small elevation change between the parallel friction surfaces makes drum removal more entertaining…🤦‍♂️
Not seen that for a while. I think it was done when the disc rear option was added in 03 and the shoes fitted to drum axles had a strip of friction material removed so the same proportioning valve could be used with disc/drum rear, and the brake force would be same as with the disc models.
You won't find new shoes like that, so you would just need normal shoes for replacement purposes. The lip in the drum would just wear a grove in the new shoes, unless you chose to replace the drums at the same time as the shoes.
Got lots of liner left to burn through, but I may just switch to a semi metallic shoe anyway. First though I have full set a new parts to replace the worn out fronts with, shiny calipers/ slotted rotors-
Repainted my Currie Rokribz (love that name) back to the original color or pretty close at least.
...yesterday afternoon.
Even after baking in the hot August sun for a few hours, still had to do a bit of "wrastlin" (as my grandfather used to say) to get the new replace-a-top installed on Tessie....but installed it is. Never realized how bad the windows were in the previous top until I had something for direct reference...I can see! :D
Before removing the top, I had noted the leading edge at the header was a little funky looking where it meets the windshield frame when clamped in place. Upon removing the header to swap it to the new top, I noticed six screw holes in it that weren't used (ever), and those unused screw locations seemed to coincide with the aforementioned visual funkiness I saw with the top under tension. Hit the local hardware for six #8 x 3/4" stainless pan heads and used an awl to punch holes through the plastic reinforcement. No more funkiness.
I did run into a couple of issues during installation, the first being that I think they reduced the length of the rear bow by 1" at some point, it's impossible to hook it in the top. The entire fabric pocket sewn in the top appears to be 1" shorter than on the previous top (2017 production).
The second issue is this tacky reflective blight...
...this can feck right off. Makes the top look cheap to my eyes. Mark your product, sure, but maybe do so tastefully with consideration for the paying customer.
Spent a couple of hours taking the driver's side door back apart to redo what I should have done the right way the first time. A few weeks ago I decided to finally replace those old wore out outer door handles on my LJ. The passenger had got to where it would take both hands to open it. So I went online to the great fount of ejication, Youtube. I found what appeared to be a couple of good videos and armed with that info started with the driver's sided door.
Fortunately I had a window handle clip tool which apparently no one in Youtube land has as they were all screwing around with picks and screwdrivers. I've done it that way but I haven't tried it like that since the mid 70s. The tool makes it much quicker altough those "dammit" clips can still fly off into lower earth orbit if you're not careful. One thing I did find out quickly that replacing that outer handle can be difficult with the window glass in there, but I managed it. Those wedges want to go through where the glass is at even with it rolled all the way up.
For the passenger side, I smartened up and just took the window glass out and it was much easier and I recommend doing that way. Now on both doors I had a heck of a time getting the door panels back on. That forward top edge of the panel just didn't want to go in there. More on that in a bit.
I drove it around a bit for the past few days and yesterday I noticed that the driver's side handle had came loose and when I pulled on it could get about a quarter inch of the bottom edge of it pulled out. So this morning I took it back apart to reset the wedges that hold it place. This time I pulled the window glass out so I could use a hammer and screwdriver to tap the wedges in tight to hold them in. When you pull the glass, the rubber seal in the window frame has to come out as well as the black plastic piece in the front edge of the window frame which is held in place with two screws on the outer edge of the frame parially covered by the rubber door seal.
I figured out that when you're putting it all back togther those screws that are partially hidden by the door seal, just start them and leave them loose for a bit. When you're putting the door panel back on, pull that black triangular piece up a bit. It'll give around an inch more clearance for door panel. Once you've got the panel back in place, shove the triangular piece back down and tighten the screws. Instead of fighting the door panel for an hour or so, I had it back in a couple of minutes.
