@akajibio and billiebob should get married and have slow, under-performing children together.
Akajibio will have to moved to Canada, which I’m all in favor for.
More BB fodder for his disciples.
https://wranglertjforum.com/threads/peak-crusing-rpm.19088/post-309719
some of us drive our jeeps daily.
? I didn't get your joke?
Billie Bob lives in Canada.![]()
Hi again, after a couple years (and permission from the purse holder) the regearing is a go.
To refresh my situation:
Daily driver in the mountains of Utah (Wasatch back) with regular steep grades on the highway, between 6 and 8k above sea level. Steep moderately rough logging roads several times a year. Some light 1600 or so pounds towing of the quad on a small flatbed up into the Uintas a few trips a year.
06 rubi
4.0
42rle
32" that will become 33" with next tire purchase in a couple years.
HP Tuner with fixed shift points (will retune if need be for new gears)
2923 rpm at 75 mph if I go with 5.38 gears. Does that track?
And would that be the wiser choice over 5.13? Judging by some of the posts in the thread that mention as low as possible with the 42rle, I am thinking yes?
Edit: assuming I input the right numbers into the grim page.
I recently downsized my tires to 30 inch tires (from 31 inch).
Now I am running 4.0, 42RLE, 4.56 gears and 30 inch tires.
It drives amazing, especially acceleration with overdrive disabled. When on highway, I get around 2550RPM around 70MPH, it drives amazing.
Seems like most of the bad rap that 42RLE is getting is related to the bad gearing.
It seems to me that the correct gearing for it is(4.0 engine):
30 - 4.56
31 - 4.88
32 and higher- 5.13
What you guys think?
I would do 5.38 for 33s. 5.13 is the bare minimum for them.
Chris' chart states 5.13, Jerry and company recommended 5.13 https://wranglertjforum.com/threads/can’t-seem-to-find-revolution-gears-anywhere.52632/#post-917256
I think it may be at the point where more opinions are not necessarily helpful.
Will be a year or two before the rubi needs the new rubber, giving the increase to 33". It would be awesome if there was a consensus of 42rle + 33" =5.38, but I am not seeing one. Hell, even the folks here in Utah (pretty respected shop for all things wrangler) only advised 4.88.
Here's my present mind: I do not want to go too weak a gearing, but have no thoughts on going to 35"s. If I go 5.38 I might regret it being on the deep side. After all of the reading, all of the opinions, all of the theorycraft with the grim jeeper page, 5.13 kind of seems like the sweet spot... on paper. Trust me, I look at my rubicon axles and have given thought to the 5.38, after all it has that capability over the non-rubicon axles, why not take advantage, right?
I'd love to see a compelling case for the 5.38s with 33"s if there is one. Preferably before she goes under the wrench on the 10th.
Although I highly respect the opinion of Chirs on this forum, you will often receive feedback from others with such terms as, "we like", or "folks on this site", and "what I like". Now these terms are fine and ok for such site because we are on "their" site asking "their" opinion, but keep in mind that most opinions on this site are just how a particular combination of tire size, gear size, etc., works for a given jeep. The true answer lies on your own set of circumstances such as use of the vehicle, mostly highway, off-road, 50/50, whether your in the mountains or flat land, and of course your jeep specifically such as engine size, transmission type, etc. So what is my point? Well, my point is to take all these points into consideration and come up with your best answer to meet your specific needs. Most importantly, have fun and enjoy your jeep every step of the way and don't get lost in opinions.Chris' chart states 5.13, Jerry and company recommended 5.13 https://wranglertjforum.com/threads/can’t-seem-to-find-revolution-gears-anywhere.52632/#post-917256
ps..... don't worry about members mocking you or me for our thoughts. Its just how they are!
30 - 4.56
31 - 4.88
32 and higher- 5.13
30 - 4.56
31 - 4.88
32 and higher- 5.13
