Hi! do you know the paint code of your car? Thank u!
PGJ - Jeep Green Metallic
I really liked this upgrade! And then you removed it....Think of the aerodynamics and improved MPG! You really had something and tossed it away...
Looks gorgeous! Paint and color came out great!
Hope you keep it topless the next couple months to enjoy it in the warm weather![]()
Time for another big update! A few days ago, I picked my Jeep up from getting a completely new paint job. I kept it the original color (Jeep Green Metallic). Here are some progress pictures an employee at the shop sent me.
View attachment 621990View attachment 621991View attachment 621992View attachment 621993View attachment 621994
I took this opportunity to fully refresh the exterior of the Jeep as well. Every weather seal is brand new as are almost all trim pieces. New side mirrors, turn signal housings, door and tailgate handles, even the hood bumpers are all brand new. I'm very happy with this decision as some inexpensive parts went a long way to really making the end result look complete. The door / tailgate jambs and under hood were also repainted. Basically the only thing I didn't do is have the engine pulled to spray the engine bay itself. Here's some pictures of the finished product!
View attachment 621995View attachment 621996
View attachment 621998View attachment 621999View attachment 622000View attachment 622001View attachment 622002View attachment 622003
I also had the windshield replaced since the previous one was very pitted and it needed to be removed anyways during the paint prep. I took this opportunity to tint the full windshield with 50% nano-ceramic and also tinted the side windows with 35%. I haven't re-installed my soft top yet, but these should be a fairly close match to the 31% VLT that Bestop claims.
Lastly, I had the shop handle a few repairs for me while it was there. My shifter stick had a bit of surface rust that they cleaned up and followed with a coat of gloss black paint. I also had my pool ball paint matched to the same green as the exterior.
My spare tire carrier also had a decent amount of surface rust. Almost every OEM carrier I saw online looked the same so I opted to have this re-finished as well.
I'm extremely happy to have this stage of the build done. Next I'd like to work on cleaning up the interior. I've got some very exciting plans for a full custom sound system upgrade. Thanks for reading!
I’m painting my half doors this summer and I’m so worried I’m gonna go “well, might as well paint the rest of it since it’s 20 years old!”![]()
I've mentioned before about my plans for an audio upgrade, and thought this would be a good time to share on update on my progress / plans for that. I'll keep this relatively brief, but feel free to follow up with any questions if you're interested in my build. I'll be doing a much more detailed build log of the audio system once it's installed, this will mainly be a few examples of early prototypes I made and then a little sneak peak into my more recent designs.
I initially had planned on installing a 2-3" midrange speaker along with a tweeter in 3D printed pods mounted to my a-pillars. I ultimately abandoned this idea since I felt it would look a bit too gaudy and be prone to theft. Here are a couple pictures of an early a-pillar pod draft, these attached to the lower two screw holes that hold the OEM A-Pillar in place.
Another prototype I briefly considered was an angled 5 1/4" midrange speaker mounted in the stock location. While I would've liked to build a proper enclosure, there was neither sufficient mounting depth nor airspace available for the driver I wanted to run. These also used the original mounting holes, with the top bracket mounting from behind.
Mounted with some cheap 5 1/4" coaxials we had lying around the shop. I do not suggest mounting coaxials in this location, this was just a test fit.
I ultimately decided that the midrange should be in a sealed enclosure to prevent cancellation from the rear wave. Due to airspace and mounting depth limitations, this meant moving down to a 4" midrange. I also designed a sealed enclosure for a 4" speaker that has an angle upward.
After some further planning, I opted not to worry about angling the midrange since the tweeters I'll be running can be crossed over low enough to avoid beaming anyways.
Below is my latest design for my midrange speakers. This is a sealed enclosure, designed to be printed out of ASA (100% walls for maximum strength). This mounts to the original speaker pod mounting holes. The speaker holes are sized for M2.5 heat set threaded inserts. I also added a cutout for a Deutsch DT flange connector for the speaker wire, this has holes sized for M3 threaded inserts. The top baffle is 12.7mm thick (with a significant chamfer for airflow). The sides and back wall are 6.35mm thick.
And here is the tweeter pod. I'm still experimenting with different mount designs, but the pod shape and size is accurate. This has a built in cutout sized for 16ga speaker wire. With a small amount of hot glue around the speaker wire, it is 100% water tight.
Not a huge update by any means, but figured someone might find this interesting. Stay tuned for more updates soon!
Great use of the printer. Very cool design as well.
A few days ago I replaced my fog lights with a set of the KC Daylighters. While I initially was searching for an LED replacement, I couldn't find any that matched the retro look I'm going for. I eventually settled on the KC 100W halogen daylighters. I swapped the lenses for KC 4206 to convert them to true fog lights. Wired them up to the factory fog light switch and they work great and look much better than the old lights the Jeep came with.
Obviously hard to tell in a picture, but these are much brighter than the 55W units they replaced. After using them for a few days, I actually quite like the slightly warmer color of the halogen bulbs for fog light use. KC lists these at 4000K color temperature, here they are compared to Holley Retrobrights at 5700K for comparison.
Today, I finished up my electrical system upgrades by installing a high output alternator! I went with Ohio Generator alternator. This looks to be a remanufactured Denso alternator designed for a Durango (you may be familiar with the common 160A alternator upgrade many TJ owners do). Ohio Generator calls this a 330A alternator and claims 160A output at idle.
The original 117A alternator before removal. The bolts holding this in did not want to budge and I had to apply some serious force to get them out. Luckily, both eventually came out without breaking. I cleaned quite a bit of dirt out of the threads on the alternator mount and applied anti-seize before installing the new alternator.
OEM 117A vs Ohio Gen 330A
The new alternator uses a slightly smaller pulley, so a shorter belt is suggested. I tried a couple belts and settled on the Gates K060778, which is just shy of half an inch shorter than the K060882 I replaced.
Unfortunately, Ohio Generator did not compress the mount bushing before sending out the alternator, which meant it would not drop into the mounting bracket as shipped.
The design of the bushing makes for a difficult time pressing it in, and I struggled immensely with getting this compressed.
After trying numerous methods, I finally found a solution: a huge socket on the back of the bushing, a vice grip, and a ridiculous amount of force. I genuinely thought I was about to break the alternator when it finally broke free with a loud pop. Thankfully, no damage was done.
With the mount bushing finally compressed, the alternator dropped right in. The bolts ran in much easier after cleaning out the threads. Here is the new alternator installed along with the shorter belt.
This style of alternator has an extra mounting point that is not used in TJ applications. This ends up sitting extremely close to the coil rail, but I opted to leave it in place without modifying so as not to void any warranties.
Lastly, I swapped out the fuse running from the alternator to PDC to a 300A to compliment the new alternator. With that, my electrical upgrades are complete and the Jeep is ready for some serious amplifiers in the future!
Those fog lights look like perfect replacements for the OEM! I like the OEM fog lights a lot and those look like great replacements!
It does look like that's a Durango Alternator.
Unless it becomes an issue, I'd say run it. But most of us, myself included, who run the Durango (mine is a NAPA rebuild) just use a cutoff wheel and remove that extra ear.
I figure - when I need to replace it, the auto store counter guy won't even check my core other than to confirm it's an alternator and not rocks in the box... That's all I did when I worked at an auto store years back.
You did better than me working the fitment - mine was a really tight fit - I just used a deadblow to get it seated. Luckily - it did slide up/outward easy enough when using prybar to get it aligned (so I'm hoping not an issue for a full removal down the line).
Anyway - my tips on what you've installed. Never heard of the Ohio option but I wish & hope they've given you a great rebuild - will store them off as an option![]()
