Hi everyone,
My jeep (04 4.0L) has been having some issues lately. It started with some misfires, which I believe I have fully solved now from replacing the coil rail and plugs. Then, I noticed my bank 1 precat was glowing and definitely clogged, accompanied by a P0171 code, which I had chalked up to me not fixing the misfires in time, so I went ahead and replaced all 3 cats and the bank 1 upstream O2 sensor on the jeep.
That seems to have solved my bank 1 precat glowing red and the p0171 code, but I noticed after my last drive that the bank 2 precat is now glowing, the jeep was taking a little more effort than usual to get above 65 mph, and I had 2 new codes: P0174 and P0161, which suggests to me that I definitely have a faulty bank 2 downstream sensor and may have a faulty bank 2 upstream sensor. I've ordered the replacement sensors and will install them once they arrive, but I wanted to get y'all's opinion on what the issue is likely stemming from.
As an additional note, which may be unrelated or even normal, I noticed on my last trip across the country that when I had my cruise control set to 80 on the mountain highways, the vent settings (feet vs. face vs. defrost) would not change until I backed off of the engine power a little, so maybe that indicates a possible vacuum leak, although I have not been able to find any vacuum leaks under my hood.
In summary, do y'all think this is likely to be an O2 sensor issue, or are there other potential causes I should be ready to look into after replacing my sensors? I don't think it's clogged cats at this point because all three are brand new.
