Rock Sliders / Rocker Guards Guide
Whats the best way to fix a pre-existing hole?
I need a nutsert in that location.
Drill larger holes for larger nutsert? I was thinking a spot weld will work then drill to the correct size hole.
The beauty of the rotabroach is you can drill that with a centering jig to 17/32 and then set the nutsert. Just drill that with the 3/8 broach first to locate it perfectly.
Reactions: 06TJ35's
We use a 5ish" long piece of 1/4" x 1.25" flat bar to make the jig. 1 hole at each end for exact fit sheet metal screws of your choice. 17/32 hole in the middle. Line up the hole to center it exactly on the 3/8" hole you used the broach on to locate it perfectly, screw that in place with the 2 sheet metal screws. Sometimes you can get it close to an edge so you can clamp one end, but that's pretty rare.
Reactions: 06TJ35's and sab
Thanks for the tip!
Reactions: ColoJeep
Yup. Quality tooling is expensive. No way around that.
Specialized quality tools like the Rotabroach also provide a level of precision and craftsmanship that can make a meaningful difference in how good the final product is.
Reactions: sab
And that’s why I’m going with what Blaine suggested.
Me and precision are opposite but his method will give me the best chance at fixing this.
Reactions: jjvw
