You can stop torturing us now!
Baja Designs S2 flush mounts.
Very common to add a switch. What's trick is to have a 3 position switch so you can turn them off. No reason to blind people in the parking lot, or on the trail.Out of curiosity, has anyone set up a reverse light override switch where you can activate the backups manually when not in reverse? I just wired my backups to the taillights but would like to be able to switch them on manually if and when needed.
Sounds like a great plan. Where is the switch? On the transmission or in the shifter (on an Auto)?Very common to add a switch. What's trick is to have a 3 position switch so you can turn them off. No reason to blind people in the parking lot, or on the trail.
I’m always surprised to see HI-LIFT jacks mounted low down at the backI installed LED bulbs in the reverse light housing and additional LED pods to my swing out for more lighting.
I'M always surprised to see Hi-lifts mounted. JMHOI’m always surprised to see HI-LIFT jacks mounted low down at the back
- we keep ours mounted on top of the hood, out of harms way and it stays clean JMHO
I mounted mine on the inside of a trash can.![]()
did you ever find a solution to this. going to try and to just that?
I did this on one of my JKs and it was really convenient. I wanted to do it on the TJ but I use the Auxbeam switch panel, so no DPDT switch. Any thoughts on how to incorporate something like this with only one SPST switch?
Im trying to do this as well, using a 5 pin relay and a diodeI did this on one of my JKs and it was really convenient. I wanted to do it on the TJ but I use the Auxbeam switch panel, so no DPDT switch. Any thoughts on how to incorporate something like this with
