Mine. I use a late model Toyota pick up Electric Parking Brake (EPB) caliper, modified rotor, and then my own bracket kit I designed for the Dana 44/35.
The controller is by Pantera. Really smart guy who knows what's up with this stuff. The only downside to any of it is expense. None of it is cheap but it has a superbly high amount of force. I wanted an idea of the force, this is a piece of 1/4" 6061 I set in the caliper to space out the force gauge and prevent it from being pushed through the piston bore machining gap in the bridge. (in case you ever wondered why the bridge is shaped with two ears)
View attachment 671016View attachment 671017View attachment 671018
I'm not familiar with your rear brakes so all I have is my concerns about what I'm doing and why. I wanted to move away from anything cable actuated. Most of the OEM is moving to EPB due to the ease of adjustment and force. This EPB has a piston diameter equal to the OEM rear TJ or 48mm which was my #1 problem to solve. I've been on the hunt for one for about 8 years and it was only in 2022 that Toyota used one. Lots of 42 and 44 and lots of 51 and 54, Toy is the only 48 I've been able to find and while I could solve the problem of an out of balance bias other ways, I preferred to keep the DD aspect in the highest focus.
Aaron and Scott have both installed them with the stock TJ or similar rear calipers. I would not do that. I don't like shit that takes a lot of effort and expense and then only works half way and I do not have an unnatural attachment to lots of extra levers in the cab. If you have cutting brakes that won't lock up a single tire on one side with an open differential and the other side being driven in 4wd, quit because you have a poorly performing system. The 48mm single piston is not enough to lock up the tire. It needs one more and a lock out to keep it out of use hydraulically for DD use.
