Dyno Testing Bolt-ons On The 4.0
Hell I was happy when I found out I get a solid 11.8 Mpg rather than the 10 I thought I used to get lol🤣
My summer mpg is double my winter mpg.
Thanks @Jezza nice closeout
You're welcome. I enjoyed the process as well. It's a blast to drive. I'm going to do a Transgo shift kit on the crappy 32rh. Hopefully that with sharpen it up a bit. I may also do an e fan soon as well. Ultimately I need it mostly stock so I can mock up the turbo kit on it.
Could you tell us a bit about how the Wrangler drives on the street with all these mods done versus stock?
Is it a lot quicker than stock from light to light? How is the fuel economy? Will it spin the tires in the dry?
Thanks, Matt
Perth, Western Australia
Thanks, Matt
Check out his YouTube Oxcart Jeep Episode 13 Final Thoughts. Can't imagine a reliable 4.0 spinning the tires.
Reactions: Wildman and BlueC
Unfortunately at 7000ft altitude you loose about 40 hp. Maybe with the right drivetrain, tires, road surface, but it's a big ask.
Thanks, Matt
I feel like it's quick. I want to do another 0-60 at some point. It will spin the tires from a stop no power braking. I am still running the stock tire size though. I am going to do some additional videos at some point. My editing software decided not to play nice with a Windows update, so I have been unable to edit anything recently.
that'll teach you to mess with Bill Gates
Reactions: BlueC
Is there asummary post with all the different stages/tests? or do I need to trawl through 30+ pages to find each individual post ?
Find this stuff awesome to read about but don't need the fluff/filler :)
Yes, as mentioned, Jezza does a summary of all the different mods and his thoughts on one of his later videos.
Thanks for the response Jezza, and others. I look forward to any future videos or tests done. It's a great series and I've watched all the videos.
I'm glad I found this series as I'm building up a 4.0 currently. I chose the Howards Street Force 1 cam, which is almost identical to Isky's 256/262 cam.
It has 203 and 209 degrees duration at .050 with .445 and .448" lift on a 110 LSA. My desktop dyno simulations show it should perform similarly to the Comp 231 cam you used.
It will be combined with a freshly rebuilt .030" over block that has been decked .015". Calculated compression is 9.4:1. The head has three angle seats, back cut valves and light pocket porting. I also have HP tuners to tune it afterwards.
My XJ has 4.56 gears, AW4 and 30" tires so the revs pick up very quickly on the street. It's a lightweight build focused on street performance as it's my daily driver.
I'm looking forward to seeing how it performs!
One more question, Jezza. Is there a noticeable torque loss under 2000rpm with the 231 cam you used?
My desktop dyno simulations show that there is a torque loss from idle to 1800rpm, compares to the 96+ stock cam, and then afterwards it builds more power/torque over stock until 5000rpm or so. It seems it broadens the power/torque curve substantially.
Thanks, Matt
Reactions: Kilcarnup
I would be curious to see what the FRP tune does instead of the DIY HPTune you did on the video. He claims 10-12% increase. I have no reason to doubt that, but it would cool to see if verified.
