5632
You got blue balls
All Democrats do.
You got blue balls
All Democrats do.
Nice!! Hopefully they survive, I'm sure it'll help at least some to have them not on the bottom side
- Torque sequence: torque each lower nut of top/bottom assemblies to 40 ft/lbs. Continue this torque sequence in 10 ft/lb increments rotating the knuckle between torque sequences. Do not exceed 60 ft/lbs. If resistance is felt at 50 ft/lbs it is acceptable to stop tightening.
- The knuckle should be able to be rotated with 1 hand and will have some resistance felt. (This is the spherical rotating inside the race of the bearing.)
Well I'd started this yesterday afternoon when I'd gotten home from my appointment.
First issue I'd ran into was the lock piece for the Stage8 retainer had spun on the spindle and put a grove in the threads.
Not sure how or why. I've got a spare Stage8 kit so I'll replace that part.
Then after making a sacrificial 1 1/16" wrench that would fit around the RCV bell/boot I attempted to tighten the nuts.
And all I managed to do was round off the edges of the nuts.
So after a few hours of frustration and cussing I'd quit for the night.
Came back out this morning and got the boot off the bell..... finally after much aggravation the boot came off.
Got the cage off the axle shaft and was able to get a better grip on the nuts.
Now remember the post just above? I was looking for 40 lbs resistance when pulling the knuckle? And could go up to 60 lbs resistance.
I'll take it as a win......
This was on the passenger side knuckle.
Now to disconnect the drivers side knuckle and check it out also.
I've got a new spindle for the passenger side coming already...
Hopefully the drivers side spindle isn't damaged.
I'm pretty sure it's just a trick on the eyes with angles, but in that first spindle picture, is the outside also flared outward? Surely not or you would've played hell getting the nut off.
The guy I talked with at Stage8 said if I wanted to I could send him the bad spindles & he would Rockwell test them to see if they weren't hardened like they were supposed to of been.
So if I have time before I leave I might send them to him just to find out. Be good to know why it happened.
If they weren't, you might be able to push for some refund (at least partial) since the failure would ultimately be on them.
Well today didn't go as I'd planned.
Had an appointment with my prosthetist this morning to get the final parts for my last foot that needed the new quick disconnect plus change the pilon on my blade foot. Of course the part for my blade is on backorder.
Then went to get the oil changed on my truck plus check to see if I could get the oil changed on the motorhome. That all went good...
Get home and walk through the door to find things not as they should be... My dog who is the little guy a Shih Tzu is sitting near the door when I come inside. And I can tell something is off. But I had to pee.... But he didn't follow me into the bathroom like normal. Come out and really get a look at him and he's got blood on his head. So now I'm wondering WTF happened. I'd been gone 4 hours so I let the dogs out to go to the bathroom and my dog can barely climb back into the house so I am thinking he must be sore so give him a pain pill that I have since he's 13 and getting stoved up. This is when I notice the rest of the blood.
At this point it's all a SWAG but here is what we think happened....
My daughter brought home a puppy a couple of months ago and like puppies do it's curious and wants to play all the time but my dog isn't interested in playing anymore. So he'll growl and snap sometimes at the puppy.. Well a few times when I've been gone and just my daughter is home and this has happened her older dog would try to protest the puppy.
So the guess is that something happened to cause the older dog to use mine as a chew toy... I took him to the vet @ 1PM and didn't leave there until after 5PM. He's got stitches in his hind leg and his whole body is badly bruised. He's got a pierced ear now too. And puncture wounds in his front leg.
So right now he's sleeping off his drug cocktail and I'm sure will be sore as heck tomorrow. And now I've got a huge vet bill...
So this changes plans a little bit for me. Instead of leaving next Friday like I'd planned I'm now not going to AZ to go wheeling and will leave for TN after 7 March since he has to have his stitches removed on 6 March. And he'll be coming with me on the trip instead of staying home.
Sorry about that happening to your pup. That really sucks, I'd be so sad. But glad it isn't too serious and he will be fine with just some stitches. My guy has a notch in his ear from the cat, so it happens...
Sucks to be missing out on some wheeling but hopefully you can still get a lot in this year with the camper setup.
I'd say next year too but you're getting into the 8HP after this season aren't you![]()
