Please help.
2001 Jeep TJ 4.0 with 216,028 miles on it. Was running fine until yesterday. It's only used for short trips, rarely see's 45 MPH. Started up fine yesterday, first thing I notice, temp gage is not working. I always let it idle to operating temp.
Also notice idle is high, 1,000 after warmed up. OK, was going to vist my wife in the hospital 4 miles away.
But first, I stopped at the Pharmacy, 1/2 mile from home. Turn off car, in the Pharmacy about 15 minutes.
Back in Jeep. Cranks fine, won't start. Try again, giving it a little gas this time, struggles a little but starts and runs.
Still high idle, still temp gage dosent move. I shut in down, notice temp gage moves down a couple mm when key is turned off. Restart is the same, needs a little gas to start.
At this point, I know something is wrong. Don't want to get stranded at hospital. So, I drive back home.
Open the hood, check oil. Level is fine, although it looks a little too clean. Quick check of underhood fuses.
Check coolent level in overflow tank, an inch over full. Remove radiator cap, full of coolant. Been using Zerex G05 since I bought it 5 years ago. Leave radiator cap off. Start up Jeep, within 15 seconds, coolant is coming out of radiator.
Shut it down. I have a combustion leak tester that I used before on my wife's chevy Impala.
Was going to try it on the coolant overflow tank. Because of obvious reasons.
Although I pretty much determined blown head gasket or cracked head. Jeep was never overheated.
I will try the combustion leak test.
But how come the Temp gauge quit working? Still looking for the sender...
Thanks in advance,
Dave
Thanks in advance,
Dave
