Hello, all. I installed a complete Powerstop brake caliper/brake pad/rotor kit on my LJ on all four corners and also changed the emergency brake shoes and pins/springs. I have the original brake hoses (ordered new SS hoses but haven't arrived yet) and the original brake hard lines (as far as I am aware). I am having an issue bleeding the rear brake calipers. I barely have any flow at both calipers and only get a trickle when i pump the brakes. I used both a bleeder tool at the calipers themselves and the bleeder tool that pressurizes the system at the fluid reservoir. The front calipers are bleeding excellently and the brake pedal is firm despite the rear calipers not building pressure. What is wrong, is it the proportioning valve or the rear hoses, or something else? I also attempted bleeding the brakes with the iginition on but no dice (I had read something about the older TJs needing to be bled with the ignition on). Thanks for the help.
