Smoked Tail Lights
Intimnasc
Jeep the Other Harley Davidson
Lifetime Supporting Member
Fort Worth, Texas
Well one of those little things I can't seem to find what I want. Looking for smoked tail lights like my front clearance lights. The first set I bought I'm sending back they have studs instead of trough bolts. Below is what my fronts look like. Looked at the Quadratecs but none are smoked or direct plug in. I guess I could and would cut and splice the old connector to the new lights. Anyways y'all are golden on these things.
I would suggest you make sure the lights are bright enough for other drivers to see during bright daytime.
Adding a brighter one behind the spare.
Yes please. Most "smoked" lights are dim - I don't see the point myself.
I like the look of appearing black. No point specifically just aesthetics.
They are not legal in many areas for good reason. That doesn’t stop people from installing them, though.
Not sure about this but I'll look it up here. Good question though if I am willing to take that risk. The whole don't break the law when your breaking the law thing.
  • USA Proud
Reactions: TheBoogieman
ORO LightDOTs (or one of the knockoffs) have a black housing and don't use a red diffuser IIRC.
@ Apparition those look good do you have them on yours? Are you satisfied with the brightness?
Thank you. Half as bright as they otherwise would be.
IIRC, the light visibility is part of the requirement, but you also lose the required reflector performance.
They don't have to be huge to be compliant, I think the two they use on the JL's may be around 1.5" square mounted down on the bumper.
