Yea, you're probably fine. If not, change 'em then. One of mine was cracked, so I changed both of them.
exactly….
Plus the visors that I replaced were getting it a bit manky … so having a nice fresh set puts a smile on my face.
exactly….
You always make me work when I read your posts. ;)
manky
adjective
UK informal
used to describe an object that is unpleasantly dirty, usually because it is old or has been used a lot:
manky
adjective
UK informal
You’re welcome buddy 😂
There are some words that people in the US say that you just wouldn’t say in the UK…. Such as the word. ‘ fanny’. Lol
No, I think the word you're looking for is kinky🤣
He could have been talking about "Fanny"
Animated GIF
I took my 4.0 apart to put in new pistons because I have piston slap. Found this on the head. On the first cylinder. I’ve gotta replace the head, right? I want a cheap but good option, I was really not ready to be spending hundreds of more dollars on top of what I have for pistons. What recommendations do yall have?
  • Wow
Reactions: FarFire70
You can pull the valves to confirm - but that certainly looks like a crack.
Cheap options would be a u-pull-it or FB marketplace - you can likely get a block + head fairly cheap which should be better than just grabbing a loose head someone has had laying around. Although that's not fool proof that they didn't overheat the engine and warp it some, etc. FWIW
