I have been driving my TJ for a while and the front tires have been coming down with wear. A few weeks ago I got the dreaded death wobble on my front left tire at 45 mph. (running 33 X 12.5" tires). I took the Jeep to my local 4 wheel drive shop and they said I needed 2 new tires. I went along with that since they were weather checked pretty good.
I have 2 new tires on the front and they don't feel any better than the ones I had on before. My left wheel feels out of balance. The jeep has 110,000 miles with no steering components replaced in the past.
I'm wondering if I have a bad hub or ball joints. The Jeep has a 3" lift kit installed so the camber is slightly out. I'm thinking if I keep driving it I will eventually get the death wobble back again with the new tires. The shop is telling me the front end is tight, truly that cannot be correct. Is there a special way I should be checking these components to find the play that they may not be doing correctly???
One other issue comes into play here. In the past the vehicle was hit on the left front area. Shortly after I bought the vehicle I found a leaking cracked brake caliper on the drivers side. (and noted body filler on windshield frame). I'm wondering if the impact could have damaged the hub bearings or the knuckle, or maybe both?
So, How to find the play?
Thinking of using Timken hubs. (if needed)
Think of using Spicer ball joints (if needed) Do they make offsets to correct the camber?
Possible damaged knuckle... Who's knuckle to use?
Recommendations???
Thank You, TJ in Virginia
Recommendations???
