replaced my janky switch with a nice rocker. Wish it illuminated with running lights on.
How do you like to serve that? Sandwichs? Gravy and mashed potatoes? Around here i only find shredded pork called carnitas.delicious, but not the same thing.
What time is lunch and how far is the drive from Charlottesville Va?![]()
Drove mine down to the annual Fathers Day drag racing with my daughter.
While installing the body lift on BB, one of the grill isolators broke, I'm not gonna pay $60.00 for a used one off Ebay, so I did some digging and found Rockjock and JKS both use new extended one's in their body lift kits, Rockjock is a 1" kit and JKS is a 1 1/4" kit, so I ordered from JKS.
Just FYI for anyone looking for extended ones.
Where did you find them individually? Lost one when my brother tied a quick disconnect to it. I haven't found just one for sale.
And then the frameless soft top which is an absolute buttwhipping to get the back window on fully.
Canvas lowers I got for $40 from XJ (now TJ) Buddy. They fit great. Awesome.
Glass slider uppers I got last night which definitely are for a TJ....the posts don't line up with the holes in the canvas lowers. WTF??
I have discovered a thing and am choosing violence.
Bestop made uppers that worked with the OEM half doors. How nice of them. Then they decided, hey you know what would go really nice with the canvas upper doors? Canvas lower doors. And somebody was like "yeah, and we could make them interchangeable with the OEM steel doors so you could mix and match depending on your needs."
They killed that guy and proceeded to make a completely new set of uppers that were otherwise identical but had a completely different pattern for mounting to the canvas lowers, thereby preventing you from using the OEM uppers (or anything compatible with OEM uppers) with their new canvas lowers. That's right, they intentionally make 2 versions of the uppers. Now they could have just put the mounting holes on their canvas lowers in the same place as the OEM lowers, but they intentionally opted to tool up a 2nd manufacturing pattern. And then just for kicks they ALSO made a set of lowers that doesn't have any mount points to accept an upper. Because just not using an upper was not enough, they had to make sure you would never change your mind.
So they make 4 products that together cover all the use cases, but it could have been just 2 products and served the exact same set of purposes and required less chicanery on their part.
The only "logical" reason here is that this way they could potentially force you to buy all their products, but I would love to see the market research that told them this was the right play. Like who is buying a lower door with the understanding that you can literally never use an upper with it? Especially when it only costs 15% more to get both. And the fact that if you wanted to run both canvas and steel doors you would need to buy two different sets of essentially identical uppers? I mean, I guess it potentially generates an extra purchase, but you know you're pissing that customer off.
So after all that, I now have basically the inverse of everything I need. Half doors I don't want. Lowers that don't fit my uppers. Uppers that don't fit my lowers. And 3 hrs of driving to make all that happen.
And oh yeah, it didn't rain a drop.
Washed the Jeep yesterday to take it for my state inspection at 3pm (12 miles away). Half way there they were doing road work on the highway and traffic was backed up for 3 miles. I took a back road that was 3 miles of gravel. Everyone else knew the shortcut too.Made it there on time and my mechanic pointed out his sign with the new hourly rates.
p.s. Stopped by the car wash when he finished filling out the new decal.
Do you have a welder to make it work?
