If your profile list is still accurate i have close to the same setup. But with a np231.
I didn't need to raise the motor even more to get the vibes settled. How old are the joints and centering ball in the rear shaft?
Really the main change that seems to have set this off is the belly up skid. I have some 1" skid spacers (defeating the belly up point, but it was already bought and installed so... at least not a shovel any more) coming to try out instead of adding more height to the motor. Lifting the motor is something I have decided to not be a good idea, as the 1" spacers already led to pinching wires that I had to have repaired above the trans. I may just have to settle for having the transfer case back down. It may be my imagination but it seems to have lost a little acceleration power alongside the vibes/shudder, but could be my subconscious babying it.
In any event I plan to take off the skid to adjust the transfer savvy case shift cable, and will be pulling the rear shaft to see if it developed issues. I tend to doubt it, but covering bases.
