What fender flares do you run
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
What fender flares do you guys run , especially with 12.5 x 33" tires?
Metalcloak....I like them a lot they are extremely strong and durable and in my opinion look great. The ones I have don’t cover the entire tire but they have them all the way to 8” wide which sticks out more than 8” from the body and would cover it all the way if you wanted.
Stock, but if I were to run some other fenders I would go with MCE. Then I like JCR Defenders, MetalCloak, Genright, et. Al.
For me two things are of interest; one is if I can gain anymore room for bigger tires and two is if it is a plastic flare. I think it’s important to have plastic just for off-road purposes. If you hit them they’ll flex and won’t transfer any energy to the tub. If you hit one with a steel or aluminum flare, it’s going to cause damage to your Jeep. I’d rather just replace a flare. That said, I do like the look of MetalCloak, and especially body matched.
Stock. I'm considering MCE fenders somewhere down the road. A true high line is too much work for all the extra stuff under my hood and Metalcloaks are hideous.
Reactions: DeepSouthTJ
MCE provides more flex and a little bit more up travel over stock for the very same reasons Metalcloaks can do it. The only functional difference is that the back side of the fender opening is still stock with MCE. Unless you are willing to do some cutting and moving of sheet metal...
I'm one of the only people out there that really loves the look of stock fenders. Clearance can be an issue with them, which is why I wish for the life of me that AEV still made a highline kit. It was seriously the perfect kit. Stock appearance, but much more room.
You can still find them from time-to-time, but people want absolutely stupid amounts of money for them, more than I'd ever be willing to pay.
Reactions: Starrs
2k will get you one lol
Reactions: tomtaylz
I went back to stock flares to replace the Omix-Ada 6" flares. They took their lumps & bumps for the team, but didn't recover from the last time I laid it on its side.
Reactions: JMT and Chris
If I were to spend $4k on stock looking hood and fenders, I think I'd rather do the Jeep West style true highline where the factory fenders are raised and the hood is cut. All for free because it's already there. Then spend less than $4k on the body work to make it look clean. The end result is better clearance than AEV.
I replaced mine with stock style ones.
Half way thru the job I questioned my sanity but once the grey flares were replaced with fresh black ones I realized it was worth it!
I'm only on 31s but when I go higher I will plan my build around keeping my stock flares.
Is this the one that @David Kishpaugh and the guys at Jeep West do to the TJs? If so, I don't think I've seen any photos of it in a while. How are they extending the factory flares? Or are they using different flares?
Following with interest. Once you cut the hood and raise the fenders into their new position, you have an unsightly gap behind the wheel at the bottom of the tub. So, what do you do there?
It feels like a lot of the parts I was interested in 5+ years ago aren’t around anymore. Though I did see some home brewed high lines the other day that actually looked pretty good.
I've seen sliders added. I'll try to find pics.
That's it. The old MudB8 fender mod. He was using the factory flares.
Then it’s basically cutting the hood. I can do that. I already have sliders that come up the tub 6”.
More or less. I remember some bending and fitting of the raised fender to fit around the grill. There really isn't much to the whole thing.
