what do all the buttons and switches do?
The 2 toggles run the light bar and the OEM fogs. The others are Schrader valves for the front and rear lockers.
Currently using a bicycle pump until I figure out and get educated on a more practical solution.
Just a thoughtThat’s pretty cool, actually.
Not familiar enough with the psi requirements. Just a random thought.This is interesting, thanks for the idea. I have factory Rubicon front/rear lockers (no pumps) and based on my research and experience with the bike pump, they only require ~5 psi. I'm not sure what psi the small CO2 pump systems put out, but my concerns are blowing out the air bladders in the Rubicon lockers using something like a standard air compressor, or anything that isn't reliably and consistently regulating the psi down to what the Rubicon lockers require. I suppose one solution is purchasing the factory pumps and doing the wiring/switches, but they seem to be scarce. I've been researching options, and trying to educate myself. I do know that I don't want to spend the cash for ARB lockers that operate on more psi.
I'm not sure why I didn't do this earlier but I checked the tire pressure and holy crap, they were all over the place! Anywhere from 35-44psi. Now I have nice consistent tires.
I also discovered I should probably replace the tires sooner than I wanted. There are some big chunks of tread taken out of one of the front wheels (I'm assuming from the previous owners accident). Now I just have to decide if I should go from the current 30 inch tires up to 31 or 32. And figure out what needs to happen to do that.
In the immortal words of Limp Bizkit…"Rollin, rollin, rollin "...…Loaded up my new 35's and went and got them mounted. These General Grabber X3's were as smooth as silk on the highway.
View attachment 52652 View attachment 52653 View attachment 52654
Rigs like that are from single dudes with no kidsIn the immortal words of Limp Bizkit…"Rollin, rollin, rollin "...…
They look sweeeeeet as bro !!
go down to 26psi each. As for tires, either 31 x 10.5 (32 has less selection) maybe 33 but that might warrant a gear change. Here is mine on 31 x 10.5 Goodyear Duratracs with h&r springs and puck in the front to level it out so maybe 1.5 to 2" of lift max.I'm not sure why I didn't do this earlier but I checked the tire pressure and holy crap, they were all over the place! Anywhere from 35-44psi. Now I have nice consistent tires.
Thanks! I will tomorrow in the daylight. I still need to get my 1.25" BL so I'll have the same clearance I did with my 33's, and it should look good then.I like your flat fenders with the aggressive tires my man! Can you post pics from the front, side and back when it's back down on grade?
Looks great!!! You should show it off.
