In stock configuration does the transfer case sit with any angle or is it perfectly horizontal with no downward angle? When I put the angle finder on the output shaft I’m getting about 8 degrees downward. My transfer case has about a 1” drop so it makes sense that it is sloping downhill. If I remove the tc drop should the angle go to 0 or close? If a motor mount spacer is added without a tc drop how much downward angle will that typically put the output shaft at?
I just got rear adjustable upper control arms and currently still have the slip yoke but planning to swap that out. Just looking at different alignment options ideas. I’d like to get rid of the tc drop, however more importantly to me is I’d like to get it vibration free, currently I’m having a little vibration when accelerating.
