So my new Jeep is just a bit higher than vehicles I've worked on before... and my existing little 2 ton floor jack won't lift high enough.... any recommendations on a good floor jack for the garage?
Which HF Jack do you have?Ha, I still use my Harbor Freight floor jack. It jacks up pretty high, but at 5" of lift on 35" tires, it's not tall enough to jack my Jeep up from the tub, only the frame (a little) or the axle (a lot). I just use a 4x4 piece of wood if I need to jack it up from the tub, then put jack stands under it, then remove the jack.
I recently purchased this one off amazon for $34.00 (3 ton & 21 inches tall)
https://www.amazon.com/dp/B003ULZGFU/?tag=wranglerorg-20
Stop making me want to buy more stuff.
4 of those would be cool as hell.
I love mine, and wouldn't mind having three more for the garage. I carry mine off-road, and after using it a couple of times for other guys flats, three or four guys have also bought one.I recently purchased this one off amazon for $34.00 (3 ton & 21 inches tall)
I bought one at your recommendation about 8 months ago. I love it and keep recommending it to others. Thanks!I love mine, and wouldn't mind having three more for the garage. I carry mine off-road, and after using it a couple of times for other guys flats, three or four guys have also bought one.
So, do you normally work on your Jeep with a giant pink gorilla in the passenger seat?The tire shop i used to get my tires used HF floor jacks.
Asked the guy about it. He claimed that they work well if taken care of. IE oil changed and cleaned. Also they swap them out every 2 years before the warranty expires. (I know its cheating)
I wish i owned it. It would be the best mod everSo, do you normally work on your Jeep with a giant pink gorilla in the passenger seat?
It would definitely be an attention grabber. I’m imagining you doing 75 down the highway with that thing hanging out. BlahahaI wish i owned it. It would be the best mod ever
