Help with Rock Krawler Tie-Rod End Replacement
Cutler Nowak
Wisconisn
Screenshot_20180917-132555_Video Player.webp Screenshot_20180917-132615_Video Player.webp
I was wheeling and my joint wobbled out of the threads in the tie rod and i wobbled it back together then rachet strapped it all together and improvised. I cannot find this tie rod anywhere on the internet to replace it, or even how to fix this. can anyone help me with this. The name of the tie rod is Rock Krawler and i cannot find this part anywhere.
Yep, those are just heim joints. If you take one off, you can figure out the size and thread pitch and order a replacement from someplace like McMaster Carr: https://www.mcmaster.com/ball-joint-rod-ends
The smart thing to do would be call Rock Krawler and find out the exact size. There's a good chance they have a replacement on hand to sell you, or they'll at least tell you the size.
Reactions: MaloStapalo
Would i be able to Re-Tap the threads and put a slightly bigger thread heim joint into there? i am trying to save some money. but thank you guys for all the help
or weld it in place and you wont have to worry about it for a long time
that would work just to send it down the road, reason being i am trying to not spend money is so i can sell it. a weld should work, if not i'll figure something out. thank you
Assuming there is enough material in the tie-rod to support a much bigger heim joint, I don't see why you couldn't do that. Personally though, I'd just buy the right size heim joint, though.
Reactions: Cutler Nowak
