Hello every one.
Long time “window shopper“ of the forum, but just decided to join. I purchased a 2004 Unlimited back in January. Wanted to run my lift kit plan and long term goals by everyone and see what I’ve overlooked. The Jeep has a hardtop and full doors for the winter. Front and rear warn steel bumpers with plans to install a synthetic line M8000 sometime in the future. It spends 99% of its time on the road and only occasionally a dirt road or campsite in a field. Looking at running Rancho RS5000X (based on the reviews here) paired with OME 2 inch heavy duty coil springs. Wheels and tire are going to be stock 15x8 Ravine wheels with BFG 31x10.5x15 All-Terrains. Mainly looking for suggestions on bump stops. I’ve read through the pages here but wanted to doublecheck a few things. Based on what I’ve figured (which is probably completely wrong) I’ve come up with 1 inch of additional bump stop in the front and a 1.5 in the rear. I understand the only sure fire way is going to be cycling the suspension without the coils. I’d at least like to be close when ordering parts. ZJ tie rod and JKS Disconnects are waiting in the garage also. Disconnects are mainly just replacing worn stock end links while being adjustable for the lift. Looking forward to being a part of the forum. Here’s an older picture:
