Agree that the Core4x4 series 1 don't have the flex of even an OEM CA so that one is off the list.The problem I see with Core 4x4 Tier 1's is rigidity. Stock arms are designed to have some flex beyond what the Clevite bushings can provide. Putting too solid of an arm on could risk ripping arm mounts off the frame. Add some rust to that equation makes the scenario even worse.
Double adjustables are just a time saving/labor saving convenience for the most part. If you feel you can dial the pinion angle in on one or two adjustments and leave it, then single adjustable will work for you. I know a guy on here that is lowering his TJ back down and putting stock arms back on. He will be selling his adjustables, so I'll check for you.
For $40 more you could get the Core tier 2's with a JJ at one end. I would much more prefer that joint over a RC joint, plus you'd have something you could build on if you decide down the road to add more adjustable arms.
I run light as well for DD reasons. OME HD lift, no back seat, minimalist bumpers, and pizza cutter tires.
Sounds like the good set up, are you still using the Barnes skid?
The issue isn't the Johnny Joint. It's the rubber bushing and the limitations it might have.Someone said something that was interesting... Maybe @Jorge Bolivar . A single JJ isn't going to flex more that the factory arm. Is that true? In that case, it wouldn't make sense to do anything more than the uppers, if you didn't think you needed more flex. Otherwise, you'll have to spend more to get dual JJ control arms...
Yeah, I know. I'm just curious how much flex you get out of a stock arm, vs a single JJ, vs a Double JJ.The issue isn't the Johnny Joint. It's the rubber bushing and the limitations it might have.
When all combined the JJ will not flex more than the Clevite bushing.
Correct, not because of the JJ. As you said on Post # 30, rubber bushing is the limiting factor.But not because of the JJ, correct? The limit would still be the bushings.
If your plans are to keep using the OEM arms I will suggest to look for an used set of adjustable arms, plenty around the Face, Craig, Ebay market and in good conditions. Core 4 x 4 Tier 1 will suite your project and will combine with the OEM at the same time.
Answering your Post #6 question;
The benefit using the JJ is flex and since the arms will be combined with the OEM style clevite bushings this benefit will be limited or not noticed.
Trust me, it is any justification for use double adjustable arms unless you want to save set up time that after been dealing with the UCF ultra clearance skid adjust your pinion angle will be a walk on the park.
One thing I like to mention; re think the use of the UCF ultra clearance skid. TJ's does not require a close to flat belly to get rid of the shovel effect plus while doing a TT the drive shaft bind at full flex must be observed not to happen.
I can tell you that this Ultra clearance system is a real pain to work with.
BTW, Its nothing wrong to save 43% as long your goal are met at the end of the project.
Jorge, what did you end up going with instead of the ucf ultra high clearance ?
