That's a 2003-4 and at least in 2004, nothing was there. I moved my Rubicon locker compressors mounted there. If you mean that big hole, that's an access hole so you can get a socket down onto the nut at the top of the shock absorber.
Your evap system is located inside the rear passenger-side corner, behind the tail light. Is your P0455 code a regular thing or did it happen just once? If it was just once, could the engine have been started with the gas cap off? That will cause that code.So would the evap system be located somewhere else? I want to get rid of this code. Its the last one I have left.
Check all your rubber hoses, carefully. You've probably got a cracked one[/QUOTE
That's what I was assuming was the problem. Same with my locker houses. Those are horrible.
The charcoal canister and pump should be buried in the rear passenger corner.
However, one common place for a split hose is the pair of fuel vapor lines that pass near the mini cats.
I've never seen the evap system mounted on the bumper. When did they do that? Maybe in front of the tail light?, behind the tail light.
that is the special "easy to fix" version.....I've never seen the evap system mounted on the bumper. When did they do that? Maybe in front of the tail light?
yeah the plan is to follow the hose as best I can then start looking for replacements. Better yet, I should get a understanding how the complete system works.
Well you got me though when I'm facing the rear tail light, it's behind it. When you go to the rear door of your house and someone is on the other side of that door to unlock it for you, is that person standing behind that door or in front of it? :thinking:I've never seen the evap system mounted on the bumper. When did they do that? Maybe in front of the tail light?
Since we are dealing with automobiles, typically the front is the part that is in front of the driver, also the same end the head lights are on. The back is the other end. The left side is the one that is on the same side as the little blinky lights are when you put the turn signal on to turn left.Well you got me though when I'm facing the rear tail light, it's behind it. When you go to the rear door of your house and someone is on the other side of that door to unlock it for you, is that person standing behind that door or in front of it? :thinking:
So what happened to your windshield washer fluid bottle? Mine sits right there where the threaded holes are...
