Front axle / tires not level
If you do take another picture try to center the back tires between the fronts, I shot this with my phone on the slab so it would be parallel with the axle
75668
The inner C, welded to the axle tube, connects to the ball joints which connect to the knuckle.
How about just using a flashlight etc. so you can see the tape measure?
yes from the floor to the top of the jack stand is about 1/4" higher on the driver side
False alarm everyone. His TJ is straight.
