Looking at adding a cb to the 2000 TJ. Standard Cobra unit or the unit where everything is in the mic.? Any difference in range or performance? Thanks
Thanks guys - very helpful. Will order that one and a good antennae. Thinking 4' firestik.I'm on the TX gulf coast so a lot of flat terrain. Reach shouldn't be a problem.
Good point, and avoid bumper mount antennas. Mounts that are close to tail light level are what to shoot for.... Of course it depends on how high up on the body you mount it.
Don't forget the importance of the antenna.
http://www.rightchannelradios.com/blogs/selection-guides/18150035-cb-antenna-range-approximations
A couple things. First, if its mic goes bad you have to buy the entire radio again... you can't buy mics for it separately like you can most other CBs.So what dont you like about the Cobra 75? @Chris @Jerry Bransford. Everything else I've read recommends it side by side with the Uniden 510 and 520
