I have a 2006 tj SE with a factory radio. No factory subwoofer. Is there any chance if I take the console out there would be the factory wiring plug already there to hook up an aftermarket sub? Thank you.
No, I don't believe they are pre-wired for the factory sub unless they came with one.
But that's beside the point. The factory subwoofer wring won't work with an aftermarket sub.
At the risk of issuing a challenge would you think that? Probably not going to be plug and play but that’s not the same as not working.
Well, assuming you were to put in an aftermarket sub and the wiring was already there, what would you do for the amp powering the sub? The factory head unit can't power an aftermarket amp.
If you got the factory amp that comes in the models with a subwoofer, that can technically power an aftermarket sub, but if you read around on this, you'll see that it only powers aftermarket subwoofers in such a way that you don't even get half the power / volume out of them, so it's literally a complete waste of time.
At that point you'd just be better off putting in the factory subwoofer / amp combo (which is lackluster at best).
A few things to unpack here:
A good many aftermarket powered subs allow you to choose speaker level or line level input. If the factory output is speaker level you choose that input on your new amp/speaker. This is the way any head unit can power any amplified subwoofer, factory or not.
Now if the factory output won’t drive an aftermarket speaker that’s a speaker efficiency mismatch so you have to choose a comparable speaker by reading the x dB @ 1 watt spec. Big speakers are notoriously inefficient so it’s totally believable one might only sound half as loud as another.
If the factory output is designed to feed an outboard amp (and isn’t speaker level) you only have to ignore the power leads and just siphon off the audio signal, any voltmeter will find that in a flash.
Without ever seeing the unit in question I can guarantee you it doesn’t have a speaker level output with no speaker attached...small cheap transistor amps burn up with no load over time and that’s a liability no car company would shoulder. It may have a line level output but that implies marrying it to an amplified sub and I’m thinking that probably wasn’t the usual fourteen years ago.
So with a twelve year (or longer) old head unit, a powered sub that’s designed to take speaker level input is the most likely solution. You just pull the audio from the sound bar harness and boom.
