Looks a lot like the big cat to me.
Soooo if you Jeep gets out of control and starts going too fast...you can push 'paws'
They're supposed to be dog paws but whatever makes you happy!
Soooo if you Jeep gets out of control and starts going too fast...you can push 'paws'![]()
Hey I do the same thing, except I use google gsheets. I have way too many vehicles and toys to keep track of it in my head.Made a log book (all my vehicles get one)
FYI, if you put an @ symbol before mrblaine, he'll see your post! Otherwise, probably not likely....Replaced the stock track bar bolt (axle side) with a larger grade 8 bolt- 7/16"-20, 3" long yellow passivated bolt from ACE. I ground the old nut off its retaining tab, then ground the tab opening to capture the new grade 8 nut. Inserted the tab onto the nut using an socket larger than the nut (light interference fit). Drilled out the curry track bar bushing to 7/16". Installed bolt and nut and Torqued to 60 ft-lbs. Worked like a charm and certainly seems a lot beefier than the stock bolt- it should hold preload much better, thereby preventing the bolt hole enlargement issues which can cause wobble.
The stock bolt seems a bit undersized for the job, considering how much lateral load it has to resist...
Thanks Mr. Blaine.
I was thinking about getting a set of those. They would match my tire cover. LOL
I bought my Jeep from a used car lot on Jan 5th. I am still waiting for the registration tags and pink slip. I'm going to wait till Friday, then give the DMV or the car lot or both, a call.
Robyn's getting a ZJ conversion on her Jeep this weekend.FYI, if you put an @ symbol before mrblaine, he'll see your post! Otherwise, probably not likely....
Great work on your rig. I love the Currie setup, wish I had one, but I'm happy with my ZJ conversion...
Fingers crossed my Brown Dog engine brackets and mounts will finally show up tomorrow so I sprayed down the bolts on the engine brackets and motor mounts with Kroil today to help loosen those puppies up.
I also got the transmission bolts out and while under there poked my finger up in the frame and found my cruise control vacuum canister was flopping around loose. I ended up taking the battery and tray out to get in and bolt it back on. While I was under the hood I replaced the air filter.
Man I'm enjoying working on this so far!
