Hi folks.
I was hoping to get some opinions on a problem I have as I could not find a thread that would directly answer it.
A little background- 3 months ego I bought a 2005 4.0L manual TJ with 125,000Km (=78,000 miles).
It has no obvious mods or upgrades besides 31' tires and a roo bar (I'm in Australia
So, my problem is getting p2098 and p2096 codes, but it only happens after a long drive on the highway. Lets say after about 1 hour.
I get no other codes and the Jeep drives just fine. It seems like nothing else is wrong.
When I clear the codes they do go away and not come back unless I again go for a long highway drive.
From reading I understand these two codes are about the downstream sensors (Bank 1 and 2 in my case) reporting lean exhaust mixture.
Also from reading, I learnt the following:
How can I know if my ECU was flashed with the firmware that should have fixed it?
How do I know if this is because of the ECU bug or because of a real problem?
Is there a way to test the o2 sensors to see if they are faulty or if the problem is elsewhere?
My situation is that I'm tight on money and not many parts are available where i'm at.
The upside is that I'm very technical and will invest the time to investigate the problem so that I don't just replace parts.
I would really appreciate any help.
Thanks,
Matan.
- This is relatively common, and it's ok to reset the codes and continue.
- There is a TSB specifically for the 2005 model.
Thanks,
Matan.
